2012/12/26
this is the default mount partitions on GamePad
rootfs on / type rootfs (rw)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
none on /acct type cgroup (rw,relatime,cpuacct)
tmpfs on /mnt/asec type tmpfs (rw,relatime,mode=755,gid=1000)
tmpfs on /mnt/obb type tmpfs (rw,relatime,mode=755,gid=1000)
none on /dev/cpuctl type cgroup (rw,relatime,cpu)
/dev/block/mtdblock7 on /system type ext4 (rw,relatime,barrier=1,data=ordered,noauto_da_alloc)
/dev/block/mtdblock8 on /data type ext4 (rw,nosuid,nodev,noatime,nodiratime,barrier=1,data=ordered,noauto_da_alloc)
/dev/block/mtdblock5 on /cache type ext4 (rw,nosuid,nodev,noatime,nodiratime,barrier=1,data=ordered,noauto_da_alloc)
/sys/kernel/debug on /sys/kernel/debug type debugfs (rw,relatime)
/dev/fuse on /storage/sdcard0 type fuse (rw,nosuid,nodev,relatime,user_id=1023,group_id=1023,default_permissions,allow_other)
/dev/block/vold/179:1 on /mnt/external_sd type vfat (rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro)
I want switch sdcard partition to external_sd
if there is only one sdcard, i don`t think, at least now, that you can swap the internal with the external
and this line from here
makes me believe that somehow the internal space is the same like on the nabi tablet.
no mate, because i don`t have a gamepad, i am just trying to point you to the right direction
have a look here
http://forum.xda-developers.com/showthread.php?t=1976770&page=6
read this post and you will understand how the program works.
http://forum.xda-developers.com/showpost.php?p=34446563&postcount=41
82 Guest(s)
Devices in use: Desktop (70), Phone (10), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
