2013/02/21
1) Gamepad doenst see Wifi hotspot, Ipads, computers does, source is 1meter from Gamepad
Im using nokia E52 phone and hotspot application Joike, because other application for same purpouse dont exist.
Im tried, every possible setting, like unprotected network, protected with WEP / WPA, but iPas does see all, Gamepad crap none.
 This is very big device usage limiter for me.
Im using sandisk 64 GB card, reformated to FAT32 by some HP formater, it works, but there issues. Sometimes slowdown happens (sometime device has 20 seconds lags, without app activity, after few minutes its is ok), also sometimes is needed, reinsert the card. There is also problem, i using card without Gamepad, after that i sometime dont see all data, same with Archos file manager, after move data from internal to exernal card.
But here are work arounds, simple use Total Commander instead Archose filemanager and only card only through gamepad USB cable, after that it wokrs.
Main problem is card speed, even best Sandisk SD micro card is still slow, around 5-10 MB/s write speed.
Here are some answers:
1/ I think the problem lies on required ADHOC WiFI connections which the ARCHOS GamePad probably doesn't support. There are some modifications for other devices, I don't know if it works on the GamePad:
2/ Which 64 Gb card model is it ?
An almost 10 Mb/s writing speed is what I got with my Sandisk 64 Gb MicroSDXC.
7/ The screenshot function is usually done with Power and Vol- key combinations on recent versions of Android, I don't have my GamePad here with me to confirm it works.
2013/02/21
1) If im right for this i need root my device?
2) Yeah sandics Sandisk 64 Gb MicroSDXC.
 Slowdowns is somehow connected with Archos musi app, which i cant unistall and which continualy reporting that crashed.
7) It donw works, i tried few apps, but all of them reportors so Android screenshot service dont runs..
98 Guest(s)
Devices in use: Desktop (81), Phone (17)
Nursat
MaXXWar
adison
Zenn
nicl
FreddyBerlin
