Issues with microSD
eman2001
Forum Posts: 13
2013/02/13 - 01:38
abigor79 said
Same problem here with 32GB microSD class 10 from Samsung. It's very annoying...
eman2001, what apps have you unnistalled? Maps, Google+, and all the stuff ? Hope this will be fixed soon, the worse are the fucking hangs in suspend mode.
 yeah uninstall every google apps, but then i upgraded to the rooted firmwire and the sd card problem started all over again, i cant wait for a new firmwire to come out and fix this shit.
Blash
2013/06/03 - 16:36
Seems will never come out..
nexxus86
Forum Posts: 15
2013/06/16 - 13:25
what micro SD's does not having this issue?
Class 6? All I have are class 10.
Megabit
Forum Posts: 19
2013/06/16 - 17:00
The problem is firmware, not type or class of microSD
meow81
Forum Posts: 12
2014/04/14 - 15:24
Hi, I have a problem,  with archos gamepad 2, rooted,after loading to the desktop it doesn't automatically recognizes/loads micro sdhc 32g kingston class 4, only when i disable or enable "developer option" (on/off) then i  restart the device and the microsd is well recognized after restart…   Also i can remove it and plug it in again (when the device is in the desktop) and the microsd is well recognized.  how can i make it to recognize microsd after device start without always to switch on or off "developer options " prior to next restart ??
The device has the updated firmware, i tried also with another 4gb microsd and it is well recognized always, even without having to put on or off dev options before restarting again..
the microsd 32 gb is already formatted in fat32 also in win 7, with quick format..
Is there a configuration file that is loading in every boot/start ? So i can modify it and check the microsd check/start command options line !
Please help
update:
After unroot and root again it recognizes the microsd at startup 1 time yes and 1 time no. without modify anything in developer options..
80 Guest(s)
Devices in use: Desktop (72), Phone (8)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
