RSF said
Good evening,
Did anyone solved or knows how to solve the class 10 sd card problem, or is everyone waiting for the new firmware to fix it?
Should i buy a class 6 card, have anyone tried them out?
By the way, great forum you guys...
thanks for the feedback
Ricardo F.
We're still waiting for the next firmware update which hopefully addresses this problem.
2013/01/16
I see the ROM has been fixed issue SDcard: http://www.archosgamepad.es/#!update-microsd-mod/cl48
You can try it and feedback (because I haven't test it)
The following users say thank you to killed for this useful post:
MegabitKhông có gì để ký
My English not good. So, If I'm wrong, please correct me. Thank you very much!
2013/01/16
Megabit said
Excellent, thank you very much. Ask for "admin" If can root this firmware as the version on other Topic!Thanks
Well, as I see, Archos Gamepad don't lock bootloader, you can try root it by yourselft like as phone/tables Nexus:
_Put your device into bootloader (adb reboot-bootloader) and follow
adb devices
adb push su /data/local/su
adb push busybox /data/local/busybox
adb push Superuser.apk /data/local/Superuser.apk
adb shell chmod 777 /data/local/busybox
adb shell chmod 755 /data/local/su
adb shell chmod 755 /data/local/Superuser.apk
adb shell "cat /data/local/busybox > /system/xbin/busybox"
adb shell "chmod 777 /system/xbin/busybox"
adb shell "/system/xbin/busybox --install -s /system/xbin"
adb shell "busybox cp /data/local/Superuser.apk /system/app/Superuser.apk"
adb shell "busybox cp /data/local/su /system/xbin/su"
adb shell "chown 0.0 /system/xbin/su"
adb shell "chmod 06755 /system/xbin/su"
adb shell "chmod 644 /system/app/Superuser.apk"
Biraries of busybox, su, Superuser.apk, download here: http://www.mediafire.com/?t69nzez5137l79d
Before do, remember install AndroidJDK (one time for all devices after), also individual driver for Rockchip (in bootloader mode)
Không có gì để ký
The archos gamepad has a proprietary bootloader (which is actually the flashing mode when you use rockchip tools) on which you can not use adb, and from what i know either on other devices you can not use adb when you are in a bootloader (fastboot) mode.
Maybe you refer to the recovery mode from which usually if you have the adb drivers you can push files towards the device.
killed
2013/01/16
Thank you for your suggest, I missing a few step (my device had been rooted successful)
_S1: reboot to bootloader for flash this firmware (adb reboot-bootloader)
_S2: reboot to bootloader for flash CWM recovery (adb reboot-bootloader)
_S3: reboot to recovery and do it to root (adb reboot recovery), select mount /system
killed said
adb devices
adb push su /data/suadb push busybox /data/busybox
adb push Superuser.apk /data/Superuser.apk
adb shell chmod 777 /data/busybox
adb shell chmod 755 /data/su
adb shell chmod 755 /data/Superuser.apk
adb shell "cat /data/busybox > /system/xbin/busybox"
adb shell "busybox cp /data/Superuser.apk /system/app/Superuser.apk"
adb shell "busybox cp /data/su /system/xbin/su"
Before do, remember install AndroidJDK (one time for all devices after), also individual driver for Rockchip (for the computer could recognized device in bootloader mode)
Không có gì để ký
2012/12/30
Megabit said
Hi guys, I got the 32 GB microSD class 10 Sandisk's and my GamePad behaves abnormally! Randomly unmount and mount the memory card, making the System unstable! I also tried a Verbatim 8 GB class 10 with the same result. Have any of you tried 10 class cards to get feedback?
i had the same problem, so wat i did was to uninstall all google apps except gmail, and it fixed it, thats all you have to do. now my sd card is stable and mounted properly
2013/01/24
Same problem here with 32GB microSD class 10 from Samsung. It's very annoying...
eman2001, what apps have you unnistalled? Maps, Google+, and all the stuff ? Hope this will be fixed soon, the worse are the fucking hangs in suspend mode.
60 Guest(s)
Devices in use: Desktop (49), Phone (11)
cutierogue
