Custom Rom Sigmax-JFG (Just for Gaming) (Flash with CWM 0 Full Wipe)
totololo
31
2013/04/22 - 00:00
I believe the problem with SD card unmounting and remounting all the time is solved by this ROM ...  I don't experience it anymore ... If you still have it after installing this ROM, it may come from another app you installed.
nexxus86
Forum Posts: 15
32
2013/04/25 - 14:23
Sigma, have you changed the partition size so that there is more free memory for /data and less for /system ?
I mean if I'm not installing all the stock apps to /system it would be more useful to have the free memory allocated to /data.
sigma.nl
Forum Posts: 44
Thanks Received: 31
33
2013/04/25 - 21:35
I didn't change the partition size I only removed some apps.
Nath4n
Forum Posts: 29
Thanks Received: 6
34
2013/05/07 - 12:45
How can i flash update.img? Sigma's ROM won't load it.
Thanks Received: 268
35
2013/05/07 - 19:14
with rockchip flashing tools
Nath4n
Forum Posts: 29
Thanks Received: 6
36
2013/05/07 - 19:30
del pls
andytuinman3
37
2013/05/08 - 17:52
can someone tell me if this rom is an improvement of battery life?
condog1
38
2013/05/25 - 19:02
I have installed this  ROM and I am very happy with it,the problem is my gamepad is playing up and needs to go back to archos and I am not sure how to return it to stock ROM, removing root,cwm and anything else that should be done.my touchscreen is not working properly ,the top right hand corner of the screen is over sensitive and keeps acting like it has been pressed so the menu keeps popping up all the time spoiling my gaming any help will be appreciated.
Top ROM though thank god for people like you,cos I wouldn't know where to start
39
2013/05/25 - 19:41
Just go to archos.com website, download their firmware for the Gamepad and flash it with Rockchip Batch Tool.
It will be be back to stock firmware and stock recovery.
condog1
condog1
40
2013/05/25 - 20:13
Thanks still going to try something else to try and sort the screen problem before I send it back
matu140
41
2013/07/10 - 20:55
Why i cant install this rom on my archos gamepad?
i selected zip file to install on cwm recovery menu, then it started but when it said extracting package, it just freezed. What i did wrong?
mikerapphone
42
2013/10/17 - 13:57
flashed CWM and installed JFG Rom and now the gamepad works better than ever, haven't tested it enough to find any issues whatsoever. the only thing i noticed about the gamepad is it's battery drains a little quick even when in sleep mode using stock Rom, does JFG have battery life improvement? or is it a kernel issue? i hope we get a fix when it's available, this device has a lot to offer if the devs remain active.
thanks sigma.nl for your hard work =)
andytuinman3
43
2013/10/17 - 14:07
Sorry wrong topic
44
2013/10/17 - 14:16
I wouldn't count too much on support for the GamePad, Archos just pushed two or three updates since the product was released and it's still running the same Android system version 4.1 (with serious security issues still unfixed)
Moreover, the GamePad kernel source code released by Archos isn't usable, so there is little to expect from custom developments Confused
Reph9
45
2013/11/02 - 05:22
Hi! I've flashed this rom and i can say it is a very good rom, speedy and smooth. But I found a little problem: meanwhile in the old rom, Asphalt 8 can be installed, there's no compatibility with your rom. Why?
52 Guest(s)
Devices in use: Desktop (44), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
