Bricked Archos Gamepad
Adamas
Forum Posts: 28
31
2012/12/30 - 23:29
Again, and again, and aaagain blue box.... :(
gpusert
32
2012/12/30 - 23:47
Just try to flash it, I also had this. My findings are nothing but trial and error. One tip, don't give up! Smile Try another USB port or PC, restart the program or when it fails and it waits to timeout : plug it in another USB port and wait for it to timeout.
Here is my log of the flash :
Loading firmware...
Loading firmware Finished.
Loading firmware...
**********Restore Action**********
**********Restore Start Total<1>**********
<Layer 1-1-1> Test Device Start
<Layer 1-1-1> Test Device Fail
**********Restore Done Success<0> Fail<1> Time<75208>ms**********
Loading firmware...
<Layer 1-1-2> Download Boot Start
<Layer 1-1-2> Download Boot Success
<Layer 1-1-2> Wait For Maskrom Start
<Layer 1-1-2> Wait For Maskrom Success
<Layer 1-1-2> Test Device Start
<Layer 1-1-2> Test Device Success
<Layer 1-1-2> Check Chip Start
<Layer 1-1-2> Check Chip Success
<Layer 1-1-2> Get FlashInfo Start
<Layer 1-1-2> Get FlashInfo Success
<Layer 1-1-2> Prepare IDB Start
<Layer 1-1-2> Prepare IDB Success
<Layer 1-1-2> Download IDB Start
<Layer 1-1-2> Download IDB Fail
**********Restore Done Success<0> Fail<1> Time<63508>ms**********
Loading firmware...
<Layer 1-1-1> Test Device Success
<Layer 1-1-1> Lowerformat Device Start
<Layer 1-1-1> Lowerformat Device Success
<Layer 1-1-1> Check Chip Start
<Layer 1-1-1> Check Chip Success
<Layer 1-1-1> Get FlashInfo Start
<Layer 1-1-1> Get FlashInfo Success
<Layer 1-1-1> Prepare IDB Start
<Layer 1-1-1> Prepare IDB Success
<Layer 1-1-1> Download IDB Start
<Layer 1-1-1> Download IDB Success
<Layer 1-1-1> Reset Device Start
<Layer 1-1-1> Reset Device Success
<Layer 1-1-1> Wait For Loader Start
<Layer 1-1-1> Wait For Loader Success
<Layer 1-1-1> Download Firmware Start
<Layer 1-1-1> Download Firmware Success
**********Restore Done Success<1> Fail<0> Time<148310>ms**********
Adamas
Forum Posts: 28
33
2012/12/30 - 23:55
hmm ok ok :/ !!
but i don't untderstand : with a customfimware, or the true archos'firmware ?
EDIT :
I tried everything: the original firmware with "uptade" twice. Same mode "restores" twice. And the same things with customefirmware ...
Nothing from nothing. Knowing that every time the square was blue.
whether IDB probleme, whether "Wait for maslroom fail"...
Adamas
Forum Posts: 28
34
2012/12/31 - 02:58
After many hours of testing of any kind, it does absolutely nothing happening ....
ALWAYS blue, always the same concern for "IDB download fail", I had to do something stupid that all crashes ...
Traaaaash -_-'
eman2001
Forum Posts: 13
35
2012/12/31 - 22:29
My computer doesnt recognize mine at all, I dont know if my batter is dead or not as for the screen is black, I will charge it over night and try again, I got as far as "download firmware start" then it says
"Download firmware fail" and after that my computer doesnt recognize it at all Frown? I hope I have not bricked my device as i really like this device.FrownCry
Thanks Received: 264
36
2013/01/01 - 15:59
try to change the usb cable
eman2001
Forum Posts: 13
37
2013/01/01 - 20:30
i did, i changed it with three different USB cables but still nothing, connecting the game pad to my computer is like connecting a wire to a potato Frown, my computer doesn't make any sound anymore when i connect it, and the screen doesn't come on anymore arrrrgggggg
gpusert
38
2013/01/01 - 20:44
If you did the unbrick trick, did you kept pressing the power buttom meanwhile striking the pins of the NAND chip ?
Else if you just bricked it by setting it in flash mode and you got the IDB Download failed message, you need to do this trick.
The GamePad doesnt have it's normal bootloader anymore so it can't get into flash mode. By striking the pins you set it in an sort of low level debug mode.
Darkster
Forum Posts: 12
39
2013/01/01 - 22:01
DSC_1101.jpgImage EnlargerDSC_1103.jpgImage Enlargerwow, the hardware reset works.
thank you.
afer Installing a Bootscreen loader my Gamepad was death.
Afer Opening my Gamepad with a Credit Card, i could work the hardware reset with the Sandisc Chip.
Danke an meinen Deutschen Kollegen, du hast meinen Tag gerettet.
Genial
MrAndreV
Forum Posts: 12
40
2013/01/02 - 17:21
That's handy to know, you wouldn't mind showing this trick as a youtube video by any chance?
Darkster
Forum Posts: 12
41
2013/01/02 - 18:43
I hope that was the last time, to see my Gamepad from the Inside.
Cool
Adamas
Forum Posts: 28
42
2013/01/03 - 21:12
Hi guys!
Well, I'm not with my Archos until Sunday, but I will try to change the USB cable ...
I want you to reassure me: is that other people were in the case have not ONLY a blue square, and change cable, a green square, a sign of recovery possible?
And is it useful to try and try and try a restore when the square is blue, or is it doomed to failure?
As a reminder, I did this on two pc (win xp and seven), and different USB ports, always blue ...
(and good new year !)
Thx :/ !
gpusert
43
2013/01/03 - 22:33
Adamas said
Hi guys!
Thx :/ !
Hi Adamas, Happy Newyear!
I've done some further research on this and it seems that Blue actually means that your tablet is in Rom Mask flash mode (Low level flashmode) and should work/flash correcly!
So, yeah you should be able to restore it (as far I'm aware of, you can't brick the tablet any further then this as the rom mask mode is flash mode in hardware (the Low level thing I'm talking about))
Hope this helps!
PS : Sorry for saying that Blue was Evil earlier, I had so many colours in that box that I didn't know what it was trying to say :P
Thanks Received: 3171
44
2013/01/03 - 22:36
I do confirm Blue color is OK for the square in Rockchip Batch tool, as gpusert said, it means the NAND flash is in mask mode ready to download the firmware.
Here is a short video on a similar procedure I did on a UG802 MINI PC (it's a different device, but also uses a RK3066 SoC like the GamePad, and the flash procedure is identical).
Darkster
Forum Posts: 12
45
2013/01/04 - 10:53
I can giv you a tip, don`t use a srewdriver do open any divices, use a normal credit card, then you have no damange on your PAD,Phone ect.
Greetings Michael
64 Guest(s)
Devices in use: Desktop (57), Phone (7)
swan12
heftpflaster
