[ ROM ] ARCHOS GamePad rooted custom firmware based on update 2012/12/27
gatapass
106
2013/01/06 - 23:29
Adamas said
Youhou o /
I get home, I turn on my pc, I connect the Archos with the USB cable of my GSIII, blue box, I run the firmware update with the custome firùware, he moved the first time, everything is installed I launched the "Root Checker Basic", he seeks... " Congrulations! This device hos root access! "
Thank you again for EVERYTHING, everyone!
a blue box ?? have always been a green box
sinon adamas je suis francais, tu es sur un forum francais ? edit : oui sur open-console
I'm lost, please help me...
Adamas
Forum Posts: 28
107
2013/01/07 - 03:24
Yop j'y suis ! Tu as essayé de changer de port USB ? Carré vert ? MP moi stu préfères !
gatapass
108
2013/01/07 - 18:17
So I have an error "IDB Start" but for me from "lowerformat device start" it does not work because I do not see the percentage of completion and RK android tool I get an error for low level format .
My tablet is normally recoverable as recognized by windows and Rockchip batch tool?
and I'm really sorry for my english which should make you bleed your eyes ...
YOSOYPEPO
109
2013/01/07 - 22:58
Great job!!!
just only one question... all data/apps is lost with this install mod?
thanks
gatapass
110
2013/01/07 - 23:16
yes
YOSOYPEPO
111
2013/01/08 - 12:57
yes
Thanks. I've ijust nstalled this great mod.
gatapass
112
2013/01/08 - 18:31
please, help me, if the tablet as recognized by windows and Rockchip batch tool, is normally recoverable ?
tezlewis1988
113
2013/01/08 - 19:12
i'm not risking it, I couldn't cope with a bricked device, I will wait for a simplier way.
arschos
114
2013/01/10 - 07:46
worked, thx for the rom SmileSmileSmile
btw. strange behaviour, after flashing rockchip tool says disconected and failure after restarting and while recovery is shown at the pad -> DO NOTHING, WAIT! -> after a couple of time the new firmware boots automatically Cool
spazztl
115
2013/01/10 - 16:19
Worked like a charm . Just do it exactly as explained and no problems at all.
Thanks for your hard work on the root CoolLaugh
DarkJoker
116
2013/01/11 - 08:48
Yesterday i got a new gamepad after i bricked the last one trying to root the device. This time all went perfect at the first time with a samsung galaxy usb cable from a friend of mine. Great job from the developer of the rooted firmware - thank you so much!
Exrta tipp: if you want to navigate to the external sd card you pluged in or an external usb drive you find them in the folder "mnt" on the root of the device - like "/mnt/external_sd/..." ;)
nerwin
117
2013/01/14 - 11:01
thanks a lot its work
nerwin
118
2013/01/14 - 12:46
guys need help i manage to root the device(gamepad) it is working but every time screen off or sleep mode the touch screen is not working only i can use is the d-pad button then if i restart the device the touch screen will work again thanks in advance.
119
2013/01/14 - 12:52
nerwin,
Which firmware are using, how did you root your GamePad, did you have the problem before rooting ?
nerwin
120
2013/01/14 - 13:12
V1.0.29.JRO03H.20121220.155836
i open the short the pin on sandisk IC of gamepad  because its stock on archos logo do i need to restore again
Currently Online: oblaarggag
55 Guest(s)
Devices in use: Desktop (50), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
