[ ROM ] ARCHOS GamePad rooted custom firmware based on update 2012/12/27
-popup-
Forum Posts: 45
Thanks Received: 18
61
2012/12/30 - 14:40
@eman2001
have you tried to put the tablet in recovery mode (using + and - volume more power down) and redo the firmware flash?
eman2001
Forum Posts: 13
62
2012/12/30 - 14:53
i have
sigma.nl said
hello
i need help because my game pad is not switching on, after the update, when i switch it on all i can see is the "Archos logo entertainment your way" and it stays like that forever. what do i do. can someone pls help me. i dnt know if my device is bricked or not, is there other ways to factory reset the whole thing. i can only go into download mode and that's it. i cant do anything else Frown
Have You detached the USB cable? The gamepad sometimes take ages to boot when I have the USB cable connected to my computer.
First time boot takes a while.
i have done that but still it takes forever, after the update i turned it on and it was working fine, then when i tried to hold the volume +,- and power button to connect and update my driver on my computer that's when the problem started, my computer "windows 7 64bit" couldn't recognize it then i tried to restart the game pad it wouldn't turn on, all i can see is the booting logo and that's it nothing more, its like it goes into a boot-loop,  i have left it like that for over an hour and still nothing Frown
eman2001
Forum Posts: 13
63
2012/12/30 - 15:08
i have tried, i dot think it goes into recovery mode because when i try to do it all i can see is the tablet starting up logo and that's it, but it only goes into download mode when i hold down the volume down and power, but i don't know wat to do from there. i tried using the "rock chip batch tool v1.5" but it doesn't recognize my gamepad
gpusert
64
2012/12/30 - 17:04
Hi Guys,
I have tried to flash it (followed the instuctions to the letter) but I got IDB Download failed and now it won't do anything. Any suggestions ?
I had FW 1.0
Thanks Received: 268
65
2012/12/30 - 17:17
did you used restore or upgrade ?
gpusert
66
2012/12/30 - 17:21
I Used restore
67
2012/12/30 - 17:25
have a look here
http://www.arctablet.com/blog/forum/archos-gamepad/bricked-archos-gamepad/
I suspect that certain lot of tablets are a little different than the ones that have been succesfully flashed.
gpusert
68
2012/12/30 - 17:45
globula_neagra said
have a look here
Thanks for the link, is that unbrick method safe ?
69
2012/12/30 - 17:53
Only the german guy tested it and said that it works.
gpusert
gpusert
70
2012/12/30 - 21:35
I've tried it and it works! This method is however not for the fainthearted I can tell you :P
Now only have to unbrick it again because I tried to install the ChainFire 3D driver, It's stuck on the Archos logo and only can access the dead android with the red exclamation mark.
The main thing is, the rooted firmware works and the crazy but functional method of the german guy also works!
Adamas
Forum Posts: 28
71
2012/12/30 - 21:41
please, help me! it does not work for me .... must be on both sides at once? long?
gpusert
72
2012/12/30 - 21:45
I did both sides while it was plugged in to the USB port, however sometimes it only showed up when I replugged the cable to another USB port. Be patient AND CAREFULL!! it worked for me.
Adamas
Forum Posts: 28
73
2012/12/30 - 21:47
hmm ok thank.. Second sound, the seem than an USB it's charged, but nothing...
I try again...
Adamas
Forum Posts: 28
74
2012/12/30 - 22:00
It's ok for me after many try !
BUT : "Download IDN fail " again with the "custom firmware"....
I will re test with the original new firmware of archos juste pour see ma tablette alive, and after, again try to installe the custom firmware.... I want the root !!
BIIIPBIIIP EDIT : Big fail : the same error message "prepare IDB fail" ! i try to use RKAndroidTool for "EraseIDB" but it does not recognize my tablette, while the other root program, though.... :/
Adamas
Forum Posts: 28
75
2012/12/30 - 22:33
It's ok with the option "Upgrade", she is alive !
I try again the root ha ha...
Currently Online: Stellar7
100 Guest(s)
Devices in use: Desktop (64), Phone (37)
Bokser
hamishduke
squal
squalangel
anqilan456
havetoregister
