[ ROM ] ARCHOS GamePad rooted custom firmware based on update 2012/12/27
RitterHans99
Germany
46
2012/12/29 - 18:57
I did it from 12/27, no problem
sigma.nl
Forum Posts: 44
Thanks Received: 31
47
2012/12/29 - 19:19
It should work no matter which firmware you upgrade from, stock one, last update or even a custom firmware. Just make sure you are using Rockchip Batch tool and use the Restore button.
Ok thanks, I'll flash my device tonight. Will post the results.
gr
The following users say thank you to sigma.nl for this useful post:
eman2001
-popup-
Forum Posts: 45
Thanks Received: 18
48
2012/12/29 - 19:27
WOW!!!!!!! I did the root properly!!!
Thank you for this great firmware, we hope to continue in future updates.
sigma.nl
Forum Posts: 44
Thanks Received: 31
49
2012/12/29 - 19:53
nubis said
Thanks a lot for the rooted firmware.
I have successfully flashed it, coming from stock firmware 1.0, using Win7/64bit.
Here's how I did it:
connected tablet to usb, switched off the tablet, then pressed vol+,vol-, poweron at the same time.
The tablet was still showing me a black screen (no archos logo), but Win7 complained suddenly about a missing driver. I went into the device manager, used the rockchip driver (amd64/win7) and proceeded to start the flashing tool. If your device proceeds automatically to boot Android, then you have do something wrong.
Then (still with a black screen on the tablet) I selected the rooted firmware, clicked on "restore" and waited a few minutes. The flash completed successfully. It will set everything back to default, this means all apps/settings are gone. Then it rebooted automatically.
Then I checked for root access - first SuperSU wanted an update, then Check Root didn't want to show me a root success, but then I remembered to turn on usb debugging on the tablet. Afterwards, checkroot confirmed that the tablet is rooted! :)
Thanks!
Rooted my gamepad with no problems, followed your instructions and everything was smooth and simple.
Thank everyone for there comments and helpfull tips.
gr.
cavalier666
50
2012/12/29 - 21:56
anyone got x64 working with windows 8 ? disabled driver enforcement and still not installing. cheers
Budnak
51
2012/12/30 - 02:47
It works very well. Thanks!
belstfranz
Forum Posts: 19
52
2012/12/30 - 03:12
@admin
I also installed the rooted firmware from the last official update with success! GREAT WORK! Thanks a ton.
Is there any chance that you can integrate the Mapping Tool Update in the firmware?
@all
P.S.: I bought a USB-LAN adapter just to find out that Google Market is denying ANY app installation
from a non-wireless source... I do not have any wireless service available. If somone knows how I can
get the apk file of the Mapping Tool or any other non-wireless way, it would be MUCH appreciated.
magfal
53
2012/12/30 - 09:49
Same here, works like a charm.
Megabit
Forum Posts: 19
54
2012/12/30 - 10:59
Hi guys, I'm new here and I tried your rooted firmware, successfully! I used win7 x 64 and I originally updated to version of 27/12. Thank you so much for the great job :)
DarkJoker
55
2012/12/30 - 11:11
Killed my gamepad with the update :(
PC still recognizes the gamepad but the batching tool stops everytime with a "Preparing IDB Fail".
Tried several computers with different windows versions and different cabels - same shit...
...no risk - no fun.
Megabit
Forum Posts: 19
56
2012/12/30 - 11:23
Sorry for the question, but did you use "Restore" button instead of "Upgrade"?
digix
57
2012/12/30 - 11:26
Updated successfully under Win7x64 from stock firmware 2012-12-20.
Press "restore"!
Cu
Digix
DarkJoker
58
2012/12/30 - 11:42
I pressed the restore button, but i think my nand memory or/and my usb-port is broken because i had problems before to connect the gamepad with a PC to copy data, music and pictures.
eman2001
Forum Posts: 13
59
2012/12/30 - 14:29
hello
i need help because my game pad is not switching on, after the update, when i switch it on all i can see is the "Archos logo entertainment your way" and it stays like that forever. what do i do. can someone pls help me. i dnt know if my device is bricked or not, is there other ways to factory reset the whole thing. i can only go into download mode and that's it. i cant do anything else Frown
sigma.nl
Forum Posts: 44
Thanks Received: 31
60
2012/12/30 - 14:37
hello
Have You detached the USB cable? The gamepad sometimes take ages to boot when I have the USB cable connected to my computer.
First time boot takes a while.
Currently Online: Stellar7
100 Guest(s)
Devices in use: Desktop (64), Phone (37)
Bokser
hamishduke
squal
squalangel
anqilan456
havetoregister
