[ ROM ] ARCHOS GamePad rooted custom firmware based on update 2012/12/27
NBTest
31
2012/12/29 - 01:33
anyone already successfully flashed the rooted firmware?
rrvuhpg
32
2012/12/29 - 12:35
Hello all,
Just tried and worked fine for me.
Be careful, don't go in recovery with adb command or you will have error installing driver, use hardware buttons (shut down and press Vol+,Vol- and Power at the same time) the screen must stay black.
Thanks a lot for this rooted firmware!
PS: I was on stock 1.0.0 fw
sigma.nl
Forum Posts: 44
Thanks Received: 31
33
2012/12/29 - 13:05
rrvuhpg said
Hello all,
nice to see someone has successfully rooted the gamepad, I want to root my gamepad but don't want to brick it like the_jako but I need Root to move all the gamedata from the big gameloft games to my external sdcard and that's only possible with apps like Directory bind but that need root access.
What OS are you using? I'm on windows 8 x64 but also have a windows 7 x64 (think I'll do it with win7)
Is there a way to do a nand backup? (probably only with root tools :) i Think, anyone any suggestions
to the_jako:
Is your gamepad still bricked or did you manage to fix it?
grtz
rrvuhpg
34
2012/12/29 - 13:12
sigma.nl said
rrvuhpg said
Hello all,
to the_jako:
grtz
I'm on Win7 x64, maybe the_jako has applied the Archos update before flashing??
Thanks Received: 3177
35
2012/12/29 - 13:28
If you are not confident in flashing, don't do it ! Wink
It's good that we have at least one positive feedback with the tests, I'll do more tests in a few days and I'll provide another rooted firmware that's easier to flash.
diger
36
2012/12/29 - 13:39
Flashed without any problems (Win 7 x64 in Parallels VM on Mac OS X)
Mick2K
Forum Posts: 13
Thanks Received: 8
37
2012/12/29 - 14:27
Hello!
Can someone help me? I'm on Windows 8 and i cant install the driver for Rockflash.
If i disable the driver signature... in windows i can install it but the Device can't be reckognized by Windows.
the_jako
Forum Posts: 25
Thanks Received: 5
38
2012/12/29 - 14:57
sigma.nl said
rrvuhpg said
Hello all,
to the_jako:
grtz
Still bricked and dont know how to do now. I'll try more things in a few days I'm out for Xmas
Anyway the fault was mine I pressed the update button instead of the restore. Be careful!!
Thanks for the root and hope I could try it soon.
RitterHans99
Germany
39
2012/12/29 - 15:29
Installed rooted FW without problems, works like a charm
sigma.nl
Forum Posts: 44
Thanks Received: 31
40
2012/12/29 - 15:37
to everyone that did a succesfull flash please post if you flashed from stock firmware 1.0 or flashed fro the recent update from 27 dec.
grtz
nubis
Thanks Received: 4
41
2012/12/29 - 16:22
Thanks a lot for the rooted firmware.
I have successfully flashed it, coming from stock firmware 1.0, using Win7/64bit.
Here's how I did it:
connected tablet to usb, switched off the tablet, then pressed vol+,vol-, poweron at the same time.
The tablet was still showing me a black screen (no archos logo), but Win7 complained suddenly about a missing driver. I went into the device manager, used the rockchip driver (amd64/win7) and proceeded to start the flashing tool. If your device proceeds automatically to boot Android, then you have do something wrong.
Then (still with a black screen on the tablet) I selected the rooted firmware, clicked on "restore" and waited a few minutes. The flash completed successfully. It will set everything back to default, this means all apps/settings are gone. Then it rebooted automatically.
Then I checked for root access - first SuperSU wanted an update, then Check Root didn't want to show me a root success, but then I remembered to turn on usb debugging on the tablet. Afterwards, checkroot confirmed that the tablet is rooted! :)
Thanks!
The following users say thank you to nubis for this useful post:
Mick2K, sigma.nl, shakan
-popup-
Forum Posts: 45
Thanks Received: 18
42
2012/12/29 - 17:39
Hello everyone, I would like to flash my gamepad but I did the upgrade of 27.
In your work or can cause a brick?
43
2012/12/29 - 18:01
It should work no matter which firmware you upgrade from, stock one, last update or even a custom firmware. Just make sure you are using Rockchip Batch tool and use the Restore button.
sigma.nl
-popup-
Forum Posts: 45
Thanks Received: 18
44
2012/12/29 - 18:04
thanks
Armageddon
45
2012/12/29 - 18:25
Hello Friends 2 Archos Gamepads successfully rootet,Thanks soooo much is very,very easy!!!!Cool
Currently Online: ri9000, hamishduke
71 Guest(s)
Devices in use: Desktop (65), Phone (8)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
