[ ROM ] ARCHOS GamePad rooted custom firmware based on update 2012/12/27
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/28 - 23:18
try holding the power button, and see if it recognizes riflasha the original firmware
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/28 - 23:19
tried and... nothing! :(
Edit: Got this problem... :(
ErrorFlash.JPGImage Enlarger
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/28 - 23:29
have you tried to contact the admin?
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/28 - 23:33
Yes, just do it again. Hope there is a solution for this... :P
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/28 - 23:35
have you done? now it work?
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/28 - 23:45
you do that?
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/28 - 23:55
-popup- said
you do that?
No, I dont fix it. I said I sent a msg to the admin. Be careful and dont use the forum like a chat because sometimes it fill the threads with useless messages.
And yes, my gamepad still bricked
Thanks Received: 268
2012/12/29 - 00:30
There is an option in another rockchip tool to erase IDB, usually it solves the problem.
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/29 - 00:32
But the PC didnt recognize the Tablet!
2012/12/29 - 00:42
can you get in the dowloading mode ?
what colour is the box when you connect the tablet in downloading mode ? pink ,green, yellow ?
can you get the tablet in recovery mode (the image with the android with a red exclamation sign)
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/29 - 00:46
someone managed to install the firmware correctly?
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/29 - 00:46
No,I cant boot in any mode. The screen dont turn on and the computer dont detect any usb device.
I tried all the combinations, recovery, download...and nothing.of course the flasher dont detect any device :(
2012/12/29 - 00:50
send a pm with a password and id from teamviewer and i will try to solve it
the_jako
the_jako
Forum Posts: 25
Thanks Received: 5
2012/12/29 - 00:56
Sent. Thanks a lot!
-popup-
Forum Posts: 45
Thanks Received: 18
2012/12/29 - 00:59
I know you would do if you reset?
Currently Online: Stellar7
90 Guest(s)
Devices in use: Desktop (63), Phone (28)
Bokser
hamishduke
squal
squalangel
anqilan456
havetoregister
