ARCHOS GamePad rooted custom firmware based on update 2012/12/27
Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5Topic Rating: 5 Topic Rating: 5 (14 votes)
2012/12/26
00:15
Forum Posts: 3688
Thanks Received: 1025
Online
JMI Pulse 10
Here is a first rooted custom firmware release based on Archos firmware update from December 27th, 2012.
Update history
Fix an issue with several buttons pressed simultaneously.
Fix an issue with the display flickering.
Fix an issue with Google talk no sound on loudspeaker on video chat.
Android build: archos/RK3070GP/A70GP:4.1.1/JRO03H/20121220.155836:user/release-keys
Linux Kernel build: Linux version 3.0.8+ (lfzhou@midcs-desktop) (gcc version 4.4.3 (GCC) ) #7 SMP PREEMPT Thu Dec 20 09:21:59 CST 2012
Rooted firmware Download: [[** please register to see this link **]]
Please do not reupload or mirror this file.
Flash only with [[** please register to see this link **]], use Restore button.
Quick firmware flashing update procedure, thanks to [[** please register to see this link **]].
I have successfully flashed it, coming from stock firmware 1.0, using Win7/64bit.
Here's how I did it:
connected tablet to usb, switched off the tablet, then pressed vol+,vol-, poweron at the same time.
The tablet was still showing me a black screen (no archos logo), but Win7 complained suddenly about a missing driver. I went into the device manager, used the rockchip driver (amd64/win7) and proceeded to start the flashing tool. If your device proceeds automatically to boot Android, then you have do something wrong.
Then (still with a black screen on the tablet) I selected the rooted firmware, clicked on "restore" and waited a few minutes. The flash completed successfully. It will set everything back to default, this means all apps/settings are gone. Then it rebooted automatically.
Then I checked for root access – first SuperSU wanted an update, then Check Root didn't want to show me a root success, but then I remembered to turn on usb debugging on the tablet. Afterwards, checkroot confirmed that the tablet is rooted! :)
This firmware has been confirmed to work by several forum users.
You should be able to flash this test firmware safely and flash back the stock firmware from Archos if things go wrong. Feedback is welcome.
the_jako, gpusert, DUDU, Mick2K, arschos, yunder, shakan, qwadrwr, diger, YOSOYPEPO, lenn2226, sirnono, Neurologe, fenix2011, hillsncoffee, fozzie24, PopEi
2012/12/26
09:01
Forum Posts: 24
Thanks Received: 5
WOW!!! Thanks a lot! I'm dying to try it!
If you need someone to test anything just tell me.
The following users say thank you to the_jako for this useful post:
-popup-, belstfranz, h4ckint0sher73
2012/12/26
14:22
Archos GamePad
when we will be able to download the root firmware?
2012/12/26
15:00
Forum Posts: 3688
Online
JMI Pulse 10
When we are done with the firmware modifications and tests, probably a couple of days.
eman2001, blaqf00t
2012/12/27
18:54
Forum Posts: 45
Thanks Received: 16
GREAT!!!!!!!
Thanks a lot!!!!!
2012/12/28
01:12
The new firmware seems to come pre-rooted and is easy to modify.
2012/12/28
01:19
Forum Posts: 45
Thanks Received: 16
But you can already install the firmware rooted?
2012/12/28
01:25
Forum Posts: 45
Thanks Received: 16
has released a new firmware archos, I can easily update and wait for the root or if I upgrade then I can not do the root?
2012/12/28
11:19
Forum Posts: 24
Thanks Received: 5
Good question… well I just updated, maybe it's too late…
2012/12/28
21:39
Forum Posts: 3688
Online
JMI Pulse 10
Here is a first root custom firmware test release based on Archos firmware update from yesterday.
Please note that this firmware is built the same way as previous firmware shown in post #1, but I can't test it as I don't have my Archos GamePad with me.
2012/12/28
21:59
Forum Posts: 24
Thanks Received: 5
Downloading right now… How I can put the gamepad into recovery mode???
2012/12/28
22:11
Forum Posts: 45
Thanks Received: 16
the_jako but the firmware you mount it now? let me know how it goes!
2012/12/28
22:14
Forum Posts: 24
Thanks Received: 5
I will let you know, but right now I dont know how to put the Gamepad into Recovery mode to flash it. Could you please help me with this?
Thanks a lot!
2012/12/28
22:19
Forum Posts: 45
Thanks Received: 16
I'm not sure but I think that if you reboot the tablet by pressing and holding the power button and the volume + button and when it leaves the word archos leave only the power button.
2012/12/28
23:10
Forum Posts: 24
Thanks Received: 5
Ok. I boot into "recovery" pressing Volume + & Volume – & Power
Then follow the instruccion but in the middle of the flash I get this message
<Layer 6-1> Download IDB Fail
Well right now mi Gamepad is absolutely bick. Dont Boot. The PC didnt recognize it… nothing :'(
Any Idea?
eman2001
admin: 3688
globula_neagra: 1879
Guest Posters: 37
Members: 74744
Forums: 122
Topics: 2812
Moderators: HaroldG (117), globula_neagra (1879), exelletor (344)
Administrators: admin (3688)
