2013/07/10
hi all!!Yesterday my rooted gamepad crashed.Then i recovered it then worked perfectly......until i didn't see any Android folder in internal storage!!!!And when i install apps i can't see them in the tablet!!!but i can see Android folder on it with xplorer!!!Can u help me??
sry for bad english!!^^
when you say that you restored, did you used the restore option in the flashing tool ?
2013/07/10
so do you have any idea ?When i connect my htc phone everything is correct.i don't understand why my gamepad not show this mother f.... Android folder!!before having this problem ,my gamepad worked great .Then crashed when i was playing.The tablet didn't want to shut down!So i pressed power few second.No reboot.My tablet was in usb debug mode fortunately!!Since i have recovered her she seems to work normally until i haven't seen Android folder into my pc .and more Android folder was visible in gamepad but when i installed any apk i couldn't see any one in the Android folder
Im using xplore file manager.So i really don't know what happen.
My advice is to use an older flashing tool which can flash partitions one by one, also format them, and see if the situation is solved.
Try this one
http://www.arctablet.com/blog/featured/arnova-childpad7d-g3-android-4-0-4-cwm-recovery-custom-firmware/
The name is RKandroid tool
Have a look here, and try to do the same, but with the archos gamepad firmware.
http://www.arctablet.com/blog/forum/archos-titanium/unbrick-archos-101-titanium-roted-fast/
2013/07/10
Yep sorry for late reply!
i did the things like this:(note v 1.35 work!! device found)
1-load rk android tools
2-recovery mode (gamepad)
3-selected all roms
4-erase nand idb
5-opened rockchipbatchtools v 1.6
6-load image from archos site
7-set restore
8-finished succes! ^^
9-gamepad reeboot
10-gamepad on (not rooted original firmware )
So after that i have installed the simpsons the game and xplore file manager from google play .
when i open xplore i show Android folder and data (normal...=)) but when i search the simpsons the game can't see it.So my problem is the same.
Maybe i did something wrong(i 'm a newbie ^^ got gamepad since june)
thank u for your try to help me .
110 Guest(s)
Devices in use: Desktop (100), Phone (10)
smalec
marek.test@gmail.com
MINIX2021
extendedtn
salimdz16
anonymunbekannter14
