2014/02/22
what is the difference from update.zip ?
where you can download update.zip ( http://www.archos.com/us/support/support_tech/firmware.html?g=zip1 ) is written :
Firmware is another name for Operating System (OS) or System Software. Below, you will find the instructions and the latest software to update your specific ARCHOS device. You do not have to install all the updates, only the most recent one. Each update takes into account all the previous updates unless specified otherwise.
2014/02/22
Now i understand , and how to delete all the internal storage?  Maybe is the right way to make it recognize my microsd 32 gb (kingston microsdhc 32gb class4) that is now recognized 1 time yes and 1 time no, after a restart it is not recognized, i have to restart it again to make it recognize by gamepad 2.
Maybe i can answer to my question:
1- make it overwrite by put update.img in storage folder root. and make it overwrite all the internal files.
2- using factory default reset , the factory reset in the updated android image version for gamepad 2 can be found in settings -> backup and recovery… -> factory reset.
2014/02/22
Please explain better how to mount/unmount (also with a command) a microsd. and how to check if android see the microsd..
At startup (desktop) in settings > memory  -> sd card
is written:
"install sd memory - insert a sd to mount"
 but the microsd is already in its slot !
this happens 1 time yes and 1 time no after each device start.
but after this i must say that i can eject microsd manually and i put it inside again and at this point gamepad2 always recognizes the microsd the way it ever should.
i tried this 32gb microsd in archos gamepad 1 (i have also gamepad 1) and it works well, it is always recognized there and works always. it is recognized at every device start in the gamepad 1.
furthermore i tried a "16gb microsd class6 samsung" in the archos gamepad 2 and it is always recognized at every device start.
I want to know how gamepad2 check the microsd at startup, if there is a file and a line that commands the microsd check at startup, and now it works 1 time yes and 1 time no. the problem is in the microsd check at startup.
2016/09/29
meow81 said
hey those links don't work !!!!I've found these working links with filezilla
ftp://support.archos.com/Android/Themed%20Series/GamePad%202/HDD%20ARCHOS%20GamePad%202.rar
ftp://support.archos.com/Android/Themed%20Series/GamePad%202/update.img Â
Hello to everyone
I have a Gamepad 2 from Archos and I'm having problems, it does not start. It just display the Archos Logo all the time. I wanna try to do the factory reset, but I can't download the files, it ask me for user and password.
Does anybody know the user and password? O someone can help me with the files?
Thanks a lot
76 Guest(s)
Devices in use: Desktop (59), Phone (17)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
