2014/02/22
Hi, I have a problem, with archos gamepad 2, rooted,after loading to the desktop it doesn't automatically recognizes/loads micro sdhc 32g kingston class 4, only when i disable or enable "developer option" (on/off) then i restart the device and the microsd is well recognized after restart... Also i can remove it and plug it in again (when the device is in the desktop) and the microsd is well recognized. how can i make it to recognize microsd after device start without always to switch on or off "developer options " prior to next restart ??
The device has the updated firmware, i tried also with another 4gb microsd and it is well recognized always, even without having to put on or off dev options before restarting again..
the microsd 32 gb is already formatted in fat32 also in win 7, with quick format..
Is there a configuration file that is loading in every boot/start ? So i can modify it and check the microsd check/start command options line !
Please help
update:
After unroot and root again it recognizes the microsd at startup 1 time yes and 1 time no. without modify anything in developer options..
80 Guest(s)
Devices in use: Desktop (79), Phone (1)
revoltown
tdomnic024
otismaibe
Tsuna77
docentik2006
