ARCHOS G9 3G Stick
AA
2012/04/04 - 01:01
does the ARCHOS G9 3G Stick work in The Bahamas and how? given that I am a resident of The Bahamas
2012/04/05 - 11:54
According to the 3G Stick specs, it uses the following GSM frequencies: 850/900/1800/1900MHz and the following UMTS frequencies: 900/2100MHz
http://www.arctablet.com/blog/archos-tablet/archos-g9-review-3g-stick-test/
dario
2012/05/13 - 12:31
I connected my 10b G2 to an Archos G9 3G stick but, contrarily to what expected, the tablet does not recognize the stick (nothing happens, the LEDs on the stick remain off). The stick works correctly on a Win7 laptop. Any hint? Anybody else got that problem?
2012/05/13 - 18:40
As you said, the 10b G2 is advertised as 3G friendly with Archos 3G Stick.
I do not have this tablet, so I can't confirm it works, all I know is it was no problem on a 8 G2 (see video below)
The 10b G2 has 2 USB ports, right ? I don't know if it helps, but maybe you can on both the full size USB and the micro USB with an OTG cable ? A good sign would be at least to get the LED to light on the 3G stick.
Currently Online: run2droi
76 Guest(s)
Devices in use: Desktop (47), Phone (29), Tablet (1)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
