Archos launches Smart Home, part of the Connected line of products
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2014/01/02 - 16:18
ash_intro_enImage EnlargerArchos just revealed the Smart Home product for home automation of which we heard for the first time back in 2012. The Smart Home is part of the Connected Line of devices. In the centre of the whole system is the Smart Home Tablet. From the front, it looks to be just a normal Android tablet, but it is probably one of the first tablets to include an onboard temperature and humidity sensor to help take control of your home. The Smart Home Tablet easily manages and links multiple miniaturized wireless objects around your home for simplified home information and automation. The 460g heavy tablet runs on RK3168 dual-core 1.2GHz processor, has an 7" 1024x600 screen and Android 4.2.2 is the operating system. There is also 8GB of flash memory with a microSD slot for those who would like to have more. With only 512MB RAM onboard, it is not going to replace your "main" tablet, but it should be perfect for streaming multimedia and home automation.
ash_slide_01Image Enlargerash_slide_08Image Enlarger
The Smart home range further consists of the following products:
Archos Mini-Cam
The ARCHOS Mini-Cam with its wide angle lens lets you monitor your home with pictures and short videos from anywhere through the ARCHOS Smart Home App.
The magnetic stand lets you angle it to capture what you need and it’s waterproof for outside use.
Archos Motion Ball
The ARCHOS Motion ball can detect motion in a room within 10 meters and it’s waterproof for outside use. The Smart Home Application shows when there is motion over time, but the motion ball comes to life when paired in a scenario to other objects.
Archos Weather Tag
Able to detect precise temperature and humidity, the ARCHOS Weather Tag shows you variations over time in the Smart Home Application, but it’s best when used to detect events and…
38 Guest(s)
Devices in use: Desktop (32), Phone (6)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
