The Angry Birds Problem on 2918 SOC Solution found thanks to OMA
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2013/01/02
19:02
Please donate to support my work
Forum Posts: 1858
Thanks Received: 138
Archos 101 XS
The majority of you probably have noticed that the applications from the developer ROVIO eg: Angry Birds –all the versions are NOT WORKING ANYMORE if they are downloaded/updated via Play Market.
Therefore, the only action that can be held now by the possessors of a Rockchip 2918 tablet should be: sending emails to Rovio expressing your problem with the non-working apps.
Still, if you want Angry Birds, try to find older versions, in places like AppsLib.
2013/02/04
23:07
Angry Birds crash is just a shader compile bug in the Vivante Driver.
23:09
Forum Posts: 3649
Thanks Received: 968
Online
Archos 101 XS
Sweet, great job, thanks Oma Smile
2013/02/05
21:24
Sorry didn't follow the unpack/pack, any advice on how (newbbie)
2013/02/05
23:31
Blog Team
Forum Posts: 344
Thanks Received: 11
Archos 70b IT
Fixed APKs should be available on Oma's website:
(just checked out on RK2918 – they are working)
2013/02/07
22:04
Really struggling with the unpacking of the .sh file have tried opening it with cygwin but this does not 'unpack' anything.
Am I doing anything wrong or is there another way to
"unpack Angry Birds, replace file, pack, sign and install"
Bit new at this game – boy just wants angry birds working, not at the stage of buying an Apple yet though!
2013/02/07
22:18
Forum Posts: 3649
Online
Archos 101 XS
As mentioned in post #5, the files are available at the url above.
These should be the fixed versions and exelletor confirmed they work.
2013/02/07
22:27
Forum Posts: 1858
Archos 101 XS
Download the Angry Birds apps from here
If you want to work with a specific Angry Birds app, you will need to back`up the up, use an apropriate tool to unpack the app, then use this file [[** please register to see this link **]] and replace the one from the app, then repack the app, sign it, and install.
2013/02/07
23:08
Absolutly brilliant thanks for your help.
LaughSmileLaugh
2013/05/03
19:31
I made the patched versions of several Rovio games available via [[** please register to see this link **]]
These run without problems.
Many thanks to Oma for the patch!
admin: 3649
globula_neagra: 1858
Guest Posters: 36
Members: 73483
Forums: 121
Topics: 2790
Moderators: HaroldG (117), globula_neagra (1858), exelletor (344)
Administrators: admin (3649)
