r/w access
djgl3nn
Forum Posts: 11
2012/03/28 - 15:34
is there any way to edit the system/build.prop folder ?
I used arctools firmware, and i'm able to access root and stuff. But it's read only. Root explorer can't make it writable either.
If i use "the kitchen" to make a custom ROM, will it work with that ?
Thanks Received: 3169
2012/03/28 - 15:37
With the stock firmware and our custom firmware, every file under /system directory reside in a CRAMFS (ready only) partition.
We'll provide a read/write update with ext3/ext4 support soon thru the Kitchen.
djgl3nn
Forum Posts: 11
2012/03/28 - 16:02
Great, looking forward to it 🙂
Thanks Received: 264
2012/03/28 - 17:16
I`m using this apk
FILE EXPERT, this is the last free version that has root explorer and mounting options (in market these options are available now, only on the paid version )
Link : FileExpertLatest.apk
I think the build.prop is similar with the one from arnova 7cg2
just instal the app, enable root exlorat, mount the system as read/write go to the build.prop file, select`it and hold the selection for 2 seconds, a menu should appear, select open with and chose a editor from there.
2012/03/28 - 17:28
globula_neagra said
I`m using this apk
That will work when the tablet is loaded with custom firmware that has ext3/ext4 or any other filesystem with write access to /system partition, which isn't currently the case Wink
2012/03/28 - 17:49
no, it worked also on the stock rom (rooted)
2012/03/28 - 18:08
Yes, on the 7cG2, but other G2 devices (Rockchip platform based) are designed to have /system in CRAMFS (read only)
djgl3nn
Forum Posts: 11
2012/03/29 - 23:22
k few questions again :
The kitchen has check-boxes, but they don't work atm. This is probably normal since ext3 & ext4 don't work yet? ( which are part of the options)
Another question,
I used the firmware from arctools to flash the first time, which gave me a working flash player.
Then i tried again with the firmware I got from the kitchen. Worked without problems, but didn't gave me flash player. Appslib and google play both give a flash player that doesn't work on my 7bc2. Is there any explanation for that ?
(So i flashed again with arctools. So basically what's the difference between arctools and the kitchen. )
And if ext3 & ext4 is available, will it also be available through arctools ? ( so i wan't have the flash player problem, and it's just easier )
Currently Online: boris_kolomiets
106 Guest(s)
Devices in use: Desktop (96), Phone (10), Tablet (1)
allanchu
konstantin0ss
nikoscc77
hacktes
Walldos
MOUNIR 1923
Topics: 6010
Members: 260642
