2014/02/17
I know there is a sub section just for the arnova 10c g3 but i have seen no response to this issue so i am re-posting here recovery mode that wont allow you to chose any option other than reboot i don't know if anyone has solved this or found a way to work around this issue to get the tablet reset to factory ANY help at all would be greatly appreciated as i have gotten no response from arnova at all
I've searched high and low over the net and have found very little info in regards to the arnova 10c g3 i recently was given one that powers up but is password locked as well, when i go into the recovery mode this tablet has the same issue the volume buttons will not let you scroll to select the factory restore option, all you can do is reboot. has anyone found a way to restore this tablet to factory setting or some kind of master password code to get into the tablet, or is this just a worthless piece of junk now ??????? I can hook the tablet up to my pc and the adb recognizes it but i cant obvious change it into any sort of debugging mode so i have no idea if there is any work around's……
Any info on this would be greatly appreciated including possibly a repair shop in the us that maybe reasonable if they can wipe and reinstall the original firmware as i cant seem to find that anywhere on the net either.
56 Guest(s)
Devices in use: Desktop (50), Phone (6)
cutierogue
