Help!! Arnova 8 g2 bricked - can't even boot up
JCR1987
2012/03/11 - 21:54
I'm hoping someone can help. I got the Arnova 8 G2 last week and promptly changed the firmware from the stock version supplied to the EZ custom firmware. All seemed fine initially except for a couple of minor glitches, but most things worked fine.
I left the tablet on charge overnight yesterday as i'd been having issues with the battery life since changing the firmware, but after i turned it on this morning it wouldn't load up to the home screen, merely cutting out and resetting itself, and going through this procedure again and again until i disconnected the charger. I managed to do the reset and + procedure to get into the setup files, but after i failed to reset it to factory settings, i tried to do a system recovery. Now that has completely screwed the tablet!!
When i plug the tablet in with the charger it starts with the Arnova screen, then goes to a message saying:
Recovery System v1.3.37
===Recovery===
Checking firmware...
After this the screen flashes and it resets itself, looping through this procedure over and over. I only got further than this first line once, at which point it said "Error on Line 12" then "reboot to attempt recovery again" and then reset itself.
I can't even see the tablet via usb to reinstall the original firmware.
Any help welcomed.
JR
Thanks Received: 3169
2012/03/12 - 16:23
JR,
Even if your tablet doesn't seem to work or connect to your computer thru USB, you should be able to flash your tablet again using Rockchip Flashing tool. http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
JCR1987
2012/03/13 - 01:26
It just WILL NOT FLASH. Every time i plug in the pc via usb or via the mains, it goes through the recovery procedure to the point where it tells me it hasn't worked. It does this if i have the sd card in or sd card out.
Here's the process:
1. Tablet is connected to laptop via usb - however the laptop can't see the tablet, but it still powers it
2. System Recovery begins - dialogue is as follows:
Recovery system v1.3.37
===RECOVER===
Please KEEP your USB cable or DC-in connected
Writing SYSTEM...
Checking SYSTEM...
Formatting CACHE....
Formatting DATA...
Formatting PAGECACHE....
E: Can't format PAGECACHE:
E: Failure at line 12:
format PAGECACHE:
Recover failed, please reboot and recover again
After the above procedure has run the blue list of options appear at the top of the screen - As follows:
Android system recovery utility v1.3.37
Reboot system now
Factory reset
Update from SDCARD
Update from uDisk
Factory test
When these options appear the screen is frozen on the first option - Reboot system now. I can't move up or down the menu with the + or - buttons. The only button that does anything is the one with 4 lines, which is the ok button and the tablet promptly reboots, only to go through the entire procedure again.
Any ideas anyone?
114 Guest(s)
Devices in use: Desktop (93), Phone (18), Tablet (3)
offcrash
mrbit
LeonDCA
mrscharling
ebbi1978
Luis1961
Topics: 6030
Members: 261555
