2011/12/30
Hello, my name is ROB and this is my first post having only purchased a Archos 8 G2 this week. All my previous devices have been resistive touchscreens using a stylus and I have always used a screen protector. My new device is of course capacitive touchscreen which is meant to be operated by finger touch. Since my finger is considerably softer than a plastic stylus, do I still need to use a screen protector and if so, where can I obtain one from? Should I buy a carry case or wallet and if so again where from. Any advice or tips you think will help a new user are welcome. Thanks for any advice and I suppose I should mention that I won't be using my device outside etc but bought it to take advantage of the free wide area WiFi available at home, thanks.
2011/10/16
If you do not have kids that are likely to get their sticky mits on your
Tablet than I would get one but beware if you get one that is
Specificaly called anti glare you will lose all the clarity on your screen.
A clear one would be better and it will enable you to clean your screen
Better without damaging it. You will need some form of protection so
Check out a specific case designed for you tablet from Amazon or Ebay
2012/11/14
Personally I wouldn't have a screen protector. because in my experience they make the touch screen less sensitive, always look scratched in the sun/bright light, start to peel off with lots of use and they so hard to fit perfectly (always get bubbles under them), so I just go with a "shock proof" case which is soft on the inside and hard on the outside.
116 Guest(s)
Devices in use: Desktop (107), Phone (9)
spiik
nikitamaan
VMILCINOV
