have you tried to reset the tablet to stock ?
Reflash firmware?
2013/04/27
Reflash firmware?
Yes, i even tried flashing your rooted firmware but it still persists. I think the problem is a lack of optimisation of the Archos firmware. Is not the same as my phone where, when i start sliding the finger, it fastly starts to scroll.
I would suggest an app the can monitor a little bit the CPU usage and have a look there if everything is ok.
When i had the 80 titanium was pretty fine in terms of responsiveness.
2013/04/27
I would suggest an app the can monitor a little bit the CPU usage and have a look there if everything is ok. When i had the 80 titanium was pretty fine in terms of responsiveness.
Wow, okay thanks for your answer, I have fixed it by freeing some ram memory by uninstalling applications... I think my tablet was overworkingÂ
67 Guest(s)
Devices in use: Desktop (59), Phone (8)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
