ADB and fastboot tutorial
Thanks Received: 3169
2012/02/16 - 11:35
What is ADB and Fastboot ? HOW TO INSTALL AND USE.
Adb and fastboot are 2 applications that help to flash and give commands to different android devices, adb and fastboot are included in the ANDROID SDK
First step is, Installing Java Runtime Environment(usually most of you, already have this if not here is the link to download http://www.java.com/en/download/index.jsp
Image Enlarger
And Java SE 7u2 http://www.oracle.com/opinions-on-teclast-p90hdchnetwork/java/javase/downloads/jdk-7u2-download-1377129.html select the edition that fits to your operating system from pc (usually is jdk-7u2-windows-i586.exe for windows7 on 32bits)
Image Enlarger
Go to: Android SDK | Android Developers http://developer.android.com/sdk/index.html , and download the pack that suits your operating system, the majority of users will download the installer_r16-windows.exe, which is for Windows XP/Vista/7
Image Enlarger
Normally Android SDK is installed in Program Files, but i recommend using the simple path like C:Android
Image Enlarger
After the installation is finished start for the first time Android SDK, and download and install the Android SDK tools and what android Api…
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/19 - 19:38
You forgot to said that we need to download adb archos driver.
And i also add that if there is some problem with PDANet for Android we will fix all problems.
Link: http://junefabrics.com/android/
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/19 - 19:43
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
2012/02/19 - 19:52
I felt that section of the tutorial was probably most mangled in the translation. I'll revisit that when I get a chance.
As far as PDANet goes, how can you tether with a wifi-only tablet? You mean connect a cell phone to the USB port and use the cell phone's data connection to get the tablet online? Wow. Hadn't thought that was possible. If it is, it's beyond the scope of this tutorial, but maybe a good idea for another one.
Harold
Currently Online: mobilstore
74 Guest(s)
Devices in use: Desktop (59), Phone (14), Tablet (2)
mobilstore
sandertb
3187
wetpax
thesandhu18
Rxne
Topics: 6030
Members: 261440
