WLAN problem with Childpad after flashing
MrKnuckels
46
2012/12/19 - 20:32
@andy.. du bist der beste!!!
So my childpad run again with wifi... thanks a lot!!!
stevedee
Forum Posts: 19
47
2012/12/19 - 20:33
For me it worked on Windows 7 Pro 64bit (with administrator rights)
Buebchen
Forum Posts: 13
48
2012/12/19 - 20:34
What was the error?
Greets
Andy :)
MrKnuckels
49
2012/12/19 - 20:50
jep,,, and now its easy...
Moojo
50
2012/12/25 - 02:49
YOU ARE THE BEST EVER,EVER YOU ARE MY HERO.......Laugh
Moojo
51
2012/12/25 - 02:50
When you have something new to childpad 3g, please you to post
BurnIT
52
2012/12/26 - 18:47
First of all: THANKS!! Display was frozen after flashing, but now everything is working... even wifi.. Thanks for the 40-050f-2g version!
Now I tried to download some stuff, because the restore deleted all included apps. Now serveral games won´t start.. f.e. AngryBirds my son loves it (and me too :-) ) Is there something I can do to get the games running?
Thanks for your help..!!
dalatt
53
2012/12/27 - 13:30
Hi, I tried everything to have wlan running after I flashed the new frmware from September but with no success. I have a pretty new capacitive childpad (502153) and tried all custom roms up to F. Any suggestion how to solve the issue?
Kind regards
dalatt66
ggtimmy
54
2012/12/27 - 15:49
I have exactly the same problem! Logged a ticket today. I hope we can find a solution.. There goes my Christmas present... :(
Tim
Buebchen
Forum Posts: 13
55
2012/12/27 - 20:30
Kind regards
dalatt66
have you testet the Original Firmware from 30.10.2012?
http://rapidshare.com/files/2109868949/Arnova_Childpad_Firmware_30.10.2012.rar
I have the 502153 too and my WLAN runs with this firmware or the firmware with PlayStore.
@ggtimmy,
i wrote to arnova on 16.12.2012, no response...
Greets
Andy
llennoc
dalatt
57
2012/12/31 - 14:02
I tried the the original firmware with no success. But I didn't try the playstore version. Do you have a link or so?
Thx
juananj
58
2013/01/20 - 18:36
llennoc said
thanks guys this fixed my wifi problem http://www.arctablet.com/blog/downloads/firmware/ArnovaChildPad/kasty-arnchilpadc-40-050f-2G.zip/
Yes.I also managed to solve the wifi problems with this firmware.Thanks so much.Laugh
AlleyKat
59
2013/02/23 - 12:54
Thank you, thank you, thank you!
kasty-arnchilpadc-40-050f-2G.zip works perfectly.
I have the capacitive 502153 too, and had some minor issues with response time, wifi stability and the missing Play option, and thus went to the Arnova website and read up on it. That pointed to doing a firmware update (FAQ -> Connecting to the Internet), and as the only available version was the Alvin one, I tried that. After which I had no wifi. Bummer!
So, I tried the Kasty 40-04, and now had no touch. So, from annoying over problematic to catastrophic... I then tried AN7DG3-CP20121012OMA4.1.zip and AN7DG3-CP20120919EV2.3.zip - still no touch. And then, after hours of reading guides, FAQs and the forums, I found this... Very nice, great job! Sure saved my day...
AdamArnold
60
2013/02/25 - 19:00
Just thought I'd add my 2p's worth to this thread.
I had all sorts of problems getting the Play store to work on Google. At first, my (well, my 4 y/o's) Childpad was completely unresponsive. Next, I lost wi-fi access.
In the end I used the file kasty-arnchilpad-40-050f-2G and - hey presto - everything worked like a charm and I can now get Google Play to work.
Now I actually have another issue, which I shall post about shortly. I am trying to activate Android Developer Tools so that I can get apps to install on my SD card.... sadly it just won't detect the advice.
In any case, massive thanks to you guys for this forum, thread and, most of all, the chap behind the 2G version!!
96 Guest(s)
Devices in use: Desktop (90), Phone (6)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
