WLAN problem with Childpad after flashing
Buebchen
Forum Posts: 13
31
2012/12/17 - 18:45
@medeni73
there are no games in the ROM, you can install the games from PlayStore.
The registration in PlayStore on ChildPad is not working, i had registration on PC and then in PlayStore on ChildPad i log in, thats working.
Now iḿ testing;)
Thanks Admin for your work :)
Buebchen
Forum Posts: 13
32
2012/12/17 - 19:26
It looks very fine, now i patch the second ChildPad with your ROMLaugh
Thanks Received: 3177
33
2012/12/17 - 19:38
Sounds good and you can always go back with your dump.
I'll soon have a look at the Google Play register and missing apps issues.
stevedee
Forum Posts: 19
34
2012/12/17 - 19:57
I tested the ROM with the capacitive Chipmunk Childpad. The result is that the touchscreen does not work anymore. So I mean the older Childpad with Chipmunk Theme. It is from a colleague.
schnellijeff
35
2012/12/17 - 20:45
Hi all,
I updated my firmware with  kasty-arnchilpadc-40-050f-2G.zip. Now all is working fine and my wifi probleme is also solved.
Many many thanks for your work.
jhofmann
36
2012/12/18 - 09:34
Hi admin,
thanks for your work!
The kasty-arnchilpadc-40-050f-2G works for me (touch and wifi ok), while  Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware without your suggested zarth.de-kernel does not work (no touch - don't know wifi), else with zarth.de-kernel (touch, but no wifi).
A bit sad - i'd like to use the 4.1.1. with complete google apps...
Regards,
Jan
medeni73
Forum Posts: 51
Thanks Received: 8
37
2012/12/18 - 09:55
It seems that there are 2 newer models (newer than Chipmunks edition) of Childpad circling around users hands: one group have/had problems with touch function AND WiFi and another one just with touch function (myself included). Touch function problem is solved with usage of "zarth.de" kernel and people that have just touch function problems can flash any custom version of firmwares they like. Those with wifi problems must wait for admin to make new 4.1.1 and 4.0.4 versions of custom firmware with new kernel and system image...
I would like to ask those users that have problems with wifi to put info of their models into topic CP Model/ FW Compatibility (http://www.arctablet.com/blog/forum/archos-arnova-childpad/cp-model-fw-compatibility/) in order to pinpoint different versions of ChildPads. In that topic you will already find some model-infos mainly from users that had just touch function problems...
Klaus
38
2012/12/18 - 23:40
the kasty-arnchilpadc-40-050f-2G worked for me as well! thank you very much! wifi is now working properly.
i'm just a little bit confused about my internal storage. my childpad should have 4GB but after connecting with my pc i have only 1GB in total (the same result in the figures of "internal storage"). Is this an issue regarding to the image above?
klaus
btw: no answer from arnova regarding to my ticket till now :-(
MrKnuckels
39
2012/12/19 - 16:11
is anyone living in the near of Hamburg?
i cant install the f*** driver for the rockbatch tool...
Thanks Received: 268
40
2012/12/19 - 17:34
install java sdk
android sdk without api`s
enable usb debugging on your tablet
install the drivers
issue the fallowing command on adb
adb reboot bootloader
open the rockchip flash tool and if the colour is green your are good to go with the flashing
If you still do not manage, check my signature.
Buebchen
Forum Posts: 13
41
2012/12/19 - 17:52
vielleicht liegt es am Tablet starten? Es darf keinesfalls bis zum umgestürzten Androiden gestartet werden.
Tablet an PC anschließen, Flashtool starten, mit Büroklammer auf Reset drücken (ist leicht fummelige Arbeit bis man da richtig trifft), dann noch den An/Aus Schalter drücken, aber nur so lange bis es am PC piept, dann alles loslassen, Tabletbildschirm ist schwarz!
Jetzt im Gerätemanager Treiber für RK29 (glaube ich) auswählen und von Hand Verzeichnis angeben (aus dem Flashtool), dann werden auch die Treiber installiert.
Ich hatte auch lange gebraucht bis ich das irgendwo gelesen hatte, ich startete immer bis zum Androiden und dann konnte ich keinen passenden Treiber installieren...
Gruß
Andy
MrKnuckels
42
2012/12/19 - 20:11
das starten ist kein prob, aber ich krieg die treiber fürs Rockchipbatch tool nicht installiert... mein win7 wehrt sich recht gut
43
2012/12/19 - 20:19
Guys, the default language on this forum is English, there is an international section if you want to continue in German.
http://www.arctablet.com/blog/forum/german/
Thank you.
stevedee
Forum Posts: 19
44
2012/12/19 - 20:24
Thank you
or here
http://www.android-hilfe.de/archos-arnova-childpad-forum/
Buebchen
Forum Posts: 13
45
2012/12/19 - 20:27
Have you start RKBatchTool.exe as Admin?
Beep your PC when you press reset and on/off switch?
When your PC driver for AN7DG3... which, thatś wrong, then you have to long pressed the buttons.
I have it tested on Windows 8, no chance.
On my Laptop is Ubuntu Linux, only on my Netbook runs Windows XP, this was good, also for the dump from the second Pad i have.
Greets
Andy
Currently Online: 5256makc
124 Guest(s)
Devices in use: Desktop (120), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
