2012/12/09
Hi all,
I searched alot but I didn't find anything for my problem. After flashing my childpad with kasty-arnchilpadc-40-050c-1G firmware my WLAN doesn't work. If I try to turn on WLAN it will turn off automatically after a few seconds.
Than I downloaded the original firmaware from arnova homepage and installed it. But the problem is still the same. It is not possible to turn on wlan.
Can anybody help me or has an idea what I can do? Many thanks in advance!!!
2012/11/30
After flashing all your settings are reset to default thus your wlan settings too. You need to enter your wlan password (WEP or WPA, WPA 2) again in order to get connected with your network.
If you have MAC protection activated on your router/modem you may enter MAC-Address of your ChildPad in configuration program from your router so it can grant your ChildPad WLAN access. If not then wlan password should do the trick
2012/12/09
Thanks,
but this is not my problem. If I go to the settings and to wlan I have to turn on the wlan before I get all access points to enter the wpa password. But if I switch on the wlan there is shown "Activating wlan?" but no action to accept. Than the switch turns to off automatically and the area on the right side shows something like: "Activate wlan to get network access".
2012/11/26
Well, the wrong kernel..... of course it depends on your HW: if it's working the kernel is not wrong
Anyway, on Arnova site you can find the official firmware
Of course, check in advance if your tab and the fw are compatible (resistive/capacitive)...
Or you could install other FW published on this forum (writing down the result of our tests);)
For those of you having troubles with WiFI, can you flash again the ChildPad stock firmware (from our link here or Arnova website) using Rockchip Batch tool ? Make sure you are using Restore button in the flashing tool.
2012/12/09
The firmware on you site is for the resistive model so I tried the one from the Arnova website. But the problem still exists.
I also tried to activate the Moblie-WLAN-Hotspot. The Pad tries to activate the Wifi, than it turns again off automatically and the Mobile-WLAN-Hotspot shows "Error". Is there a possibility to see an error log on the system. May be with root access?
First rule of the internet : Use google .
medeni73
2012/12/12
I have the same issue with my childpad (capacitive) regarding to the wifi after the official firmware update (Version 1.0 - September 26th, 2012).
after turning the wifi on a question appears "activating wlan?" and no action is choosable.
any ideas and like mentioned above, where can i get an older official firmware to go back to a functional status?
regards!
klaus
85 Guest(s)
Devices in use: Desktop (80), Phone (5)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
