2013/03/17
Dear users,
I have read the intire forum about flashing the childpad, and i must say, i'm getting real confused.
Can somebody tell me how i can put google play on the tab without the problems of the tuch screen and wifi.
My son and i wil be verry happy if you can help me.
The cildpad:Â
Version: 502153
Modelnr: AN7DG3B
Kernel: Linux 3.0.8
Buildnr: 2012.12.131.07
So if you can give me a push in the right direction.....thanks verry much!!!
Valentijn Pol
Well, have you had a look on the guide? It says that you need to get the tablet in flashing mode then install the drivers from the rockchip folder, then flash
unpack the firmware, and select with the rockchip flasher the firmware
Please read the guide with attention
In that case, you can try the alternative install method using Rockchip Batch tool.
While you keep the reset and power button pressed, connect the usb cable, and release the keys, maybe you can get it like this in flashing mode.
2013/02/10
You have the same version as me.
It cant be put into recovery mode using the method in the guide.
If you open it up, there is a button hidden inside.
I haven't been able to flash anything yet though.
captmeach7 seems to have done it, but I haven't seen a guide for it yet.
2012/12/26
I'm pretty sure you are screwing up the warranty by flashing custom firmware anyway.
You may be able to press the inside button by pressing hard on the white back cover about 4 cm straight in from the reset pinhole (the location is from memory, I had it opened 6 weeks ago, so it may be a little off). You can feel it give a little on the plastic there.
2013/04/13
Hello @ all
i have a childpad and have also the problem with the recovery mode. Its not possible to bring this thing in recovery mode. Why i have to screw up a new Device? Why its not possible to do a "normal" Update? We (my Son and I) need the Google Play Store! Because the AppSlip is just pretty Sh...! Why Arnova sell a Product which is not able to get Updated? Another thing is, if i use the Costum Firmware my W-LAN or/and the Touchscreen works not as it should to be and the Guarantee is also gone... I have also read in other Forums that after a Flash the Childpad wont start up it just hang at the Arnova Logo. Many Childpad User are really Upset about that. Could some one tell me why i should buy a Arnova Device anymore? This is my last try, if i get no Google Play Store i sell this thing on ebay.....
Greetz from Germany Papa
65 Guest(s)
Devices in use: Desktop (52), Phone (11), Tablet (2)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
