Tabeo/7DG3 can't get into recovery mode
thesniffer
Forum Posts: 13
31
2014/01/23 - 16:55
abar said
no news? EmbarassedCry
Hello abar, check your inbox please  Wink
reten
32
2014/02/15 - 13:30
please I need Flash from 0....my archos is dead.
abar
Forum Posts: 16
33
2014/02/17 - 11:00
dear friend
if you have a vimicro chip
than your chance are = 0
if you have a rockchip than you can try the original ..
but you write .. my archos is dead... what you mean?
Arnova Childpad AN7DG3C 502153
abar
Forum Posts: 16
34
2014/02/17 - 17:55
@ reten
i am italian,
there is no original software for vimicro chip, i used a software for penta 701c,
this is able to boot again the vimicro, but no touchscreen working, no camera, and screen is not alligned.
please read my post at site 2,
i need self the     sys     of a vimicro childpad, mine seem to be corrupt (touchscreen problem?)
the system dump is made from a working vimicro childpad thanks goes to    Thesniffer,
and not change much from Penta software, same problem, (touch, camera) i don't know if a 100 % requisite is to flash the original data and the original userdata of a working system, and i don't have it, there are personal userdata on it.
and only a fresh resettet childpad with root can post this, (with no personally user data). i don't wish that anyone without problem try this.
so my childpad is not working, and i have no solution for you to Repair it, i can help you only if you wish again to see it alive, but not working.
if you wish i will post the firmware that i used
greetings
abar
reten
35
2014/02/17 - 19:28
Thank you for your answer.
My archos is dead= not working. My archos have Vimicro Chip, I have tried penta software(701c) and working well but not working touchscreen and not working usb mouse. Can you post the firmware or dump system file that you used? Thank you..
rgds,
reten
abar
Forum Posts: 16
36
2014/02/17 - 19:37
please go on public chat
 i am in chat
i hope you can read this later. i used the angrybirds version, i will upload the system dump from the childpad, i will give you the link if i am ready, is important for me to know how shows the screen, plese make a foto and post it. thanks
reten
37
2014/02/18 - 14:12
hello,
I have made a foto of the screen:
but not working the touchscreen and the mouse.
Could you post the system.img original,please. Thanks
abar
Forum Posts: 16
38
2014/02/18 - 16:29
https://docs.google.com/file/d/0B2BaYVA9DB-rZjZIZTBRZlQwb2M
rooted!!!
if this works for you,
i will post one with play store.
do not forget to write me!!!
abar
The following users say thank you to abar for this useful post:
Geving
reten
39
2014/02/18 - 17:38
I will test now....thanks.
reten
40
2014/02/18 - 18:06
I have tested, now it showed ARNOVA logo but not working touchscreen and mouse......
abar
Forum Posts: 16
41
2014/02/18 - 18:51
so i have no idea how to fix it, same by me
have you access to adb ?
screen is ok?
reten
42
2014/02/18 - 19:06
I did not know how to fix it, there is a controler of touchscreen that not working....I will  do any tests...
the screen looks good...Image Enlarger
reten
43
2014/02/19 - 18:32
helloo ,
Noticeee¡¡¡,
I have gotten to enter in recovery mode, we would need only a rom type :update.zip for flash via CWM. I have tested some but not working..
To enter in recovery mode, i have erase against all via mptool and i have modificated the res.img (copy any file.img and rename to res.img to paste into mptool folder(do a copy the good res.img for the future) , the question is to fail the file res.img when is installing) after install the firware agaist. After reboot, to show recovey mode  due to failure of the res.img.
Image Enlarger
skidder
44
2014/04/06 - 00:17
Hi i am sitting in the same Boat i have an Child Pad non Chipmunks Edition bought from Amazon Germany
it's tha damn Vmicro Chipset 502153  AN7DG3 !
I have flashed a wrong Firmware with Chipmunk Branding since there no Touch and Wifi. Tried all different Firmwares nothing is helping like all other people having this Problem. The damn thing about it it's inpossible to get into flash mode nothing of the discribed combinations with PIN and Reset are working. ADB is installed correctly but it's not booting in to Flash Mode it's just restarting normaly.  Even if it would be the Tablet has no Rockchip Chipset and so the rk29 Driver will not work !!
I couldn't believe why Arnova is not Providing this Original Fimrware on there support Site there are only the Chipmunks Fimrwares ! :-(
So if any one has got some Working Fimrware for my 502153 Tablet please Help me out thanks !
abar
Forum Posts: 16
45
2014/04/06 - 20:45
no news friend. i have the same problem.
40 Guest(s)
Devices in use: Desktop (37), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
