Tabeo/7DG3 can't get into recovery mode
captmeach7
2013/11/21 - 04:45
I actually didnt use the rockchip batch tool. I used MPtool which is more generic. This tablet is another one of the generic vortex tabs like the flytouch. You will need to use the vortex.pak update. I got an english copy of the MPtools program i used, but im still looking for the particular vortex.pak. I will post tomorrow after i get home and look for it.
kingofsnakes
2013/12/10 - 23:56
Hi
I've got the same tablet. Not possible to enter recovery, SN is 502153. I'm actively looking for the correct vortex.pak. If your works, could you share it?
StupidTabeo
2013/12/13 - 23:54
That would be awesome of you! I hate having it just sit there not being used. I have even gone as far as emailing tabeo tech support but they ignored me after two emails.
thesniffer
Forum Posts: 13
2013/12/26 - 20:53
Just to let you all know that i succesfully rooted this pad with Kingo Root  Wink
chasehammer
2013/12/27 - 02:00
Yes I can confirm that Kingo Root successfully rooted this retched thing they call a Tabeo.
Now looking to install custom recovery and get stock ICS installed and maybe it can run correctly. sheesh this was waaaay too much work for a kids tablet.
thesniffer
Forum Posts: 13
2013/12/27 - 13:08
Please let me know if you get to find a proper recovery for this baby.
We could probably try to flash kasty ROM, but we need to  put tabeo kernel in that zip file before updating, to avoid touch screen and Wi-Fi failure Wink
chasehammer
2013/12/27 - 13:43
not looking good. after the root i tried to install busybox, it says it was installed but said there was an issue with the version (?), i tried installing the rockchip CWM recovery using Arctools but that didnt get me anywhere, the system will not reboot into recovery, not even stock recovery.
I tried changing the files in update.zip from the dec 2012 tabeo update but it just comes back saying the update files could not be validated. There must be some signing or something in the scipt that verifies that this is tabeo approved .img before it flashes them.
I found a walkthrough on xda to get gapps installed using busybox and then flash gordon app but even after the flash gapps it didnt take it very well.
After hours working on this last night i came to a standstill when the internal memory (sd card) no longer can be accessed from within apps or connected to my computer. I tried to do a total reset of the device but when i try that after the reboot it comes to a screen that looks grey with colors mixed without (kinda like a old tv without any signal). I think this tablet either fried inside or the files became corrupted from all my tinkering and it didnt like it.
This is also a replacement tablet from support (my 3rd actually). Its way out of warranty so i think im SOL. just thinking about trashing this crap and getting my son a $50 tablet from walgreens.
I think i hit a dead end.
thesniffer
Forum Posts: 13
2013/12/27 - 13:48
I spend almost 2 months to discover this pad was not a Rockchip one, but i'm not skilled enough to try to extract the kernel from my actual ROM.
Hope someone will get into it  Confused
abar
Forum Posts: 16
2014/01/20 - 22:40
hello, i write an how to extract the firmware from the childpad vimicro.
i really appreciate if you or another user with vimicro chipset , will spend
10-15 minutes time to do it.
you do not risk anything, you are already rooted? if not please write.
i will try to restore my semi died childpad, and if i were succefull, than we can repair some device,
and i post how to.
please help
best regards
abar
Arnova Childpad AN7DG3C 502153
thesniffer
Forum Posts: 13
2014/01/21 - 10:00
abar said
I spent almost 2 months to discover this pad was not a Rockchip one, but i'm not skilled enough to try to extract the kernel from my actual ROM.
and i post how to.
please help
best regards
abar
Hello abar, this afternoon when i'll get back home from work i'll try to follow your directions to extract the files you need from my pad.
I'll keep you informed  Wink
The following users say thank you to thesniffer for this useful post:
abar
abar
Forum Posts: 16
2014/01/21 - 13:02
thanks again for this post
please select your display dimmer to 10 min or more for this, or may be that the device goes in standby and you (can) lose the connection, after the backup is done you can already set to original 2 min, 5min or ....
abar
now i was able to install the tabeo firmware on it, wifi is OK, but display not alligned and touch not responding,
i think is the recovery.img from penta tablet that is not compatible but not sure Yell
abar
Forum Posts: 16
2014/01/21 - 17:10
IMG_20140121_163720.jpgImage EnlargerIMG_20140121_161135.jpgImage EnlargerIMG_20140121_161509.jpgImage EnlargerIMG_20140121_161802.jpgImage EnlargerSecond Update!
now with my semi dead childpad + tabeo firmware + some penta firmware, i was able to run the play store, and updated self to latest version
touchscreen nok work .
abar
abar
Forum Posts: 16
2014/01/21 - 17:29
IMG_20140121_161305.jpgImage EnlargerIMG_20140121_161946.jpgImage Enlarger
thesniffer
Forum Posts: 13
2014/01/21 - 18:10
Hello abar, check your inbox please Wink
abar
Forum Posts: 16
2014/01/23 - 15:37
no news? EmbarassedCry
65 Guest(s)
Devices in use: Desktop (57), Phone (8)
anqilan456
havetoregister
werasler
5256makc
e-victor
vienzo
