Tabeo/7DG3 can't get into recovery mode
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2012/12/25
13:44
captmeach7
I got a Tabeo (model AN7DG3C) and after using the built in upgrade app to update to the newest firmware (from TRU) it won't get past the boot animation. I have tried the reset button + power button to get into recovery, but it doesn't work. It only has those two buttons. It doesn't get to the point where my PC shows it's connected either by ADB or in device manager. Any ideas would be appreciated. TRU tech support told me he didn't even know it was made by Archos….
2012/12/25
15:11
Please donate to support my work
Forum Posts: 2028
Thanks Received: 160
Archos 101 XS
Have a look here for the flashing tools
Here is the firmware
The install procedure should be the same like here
2012/12/25
15:20
Forum Posts: 2028
Archos 101 XS
I advise you to also have a look here
Where you will find the official firmware.
2012/12/25
16:00
captmeach7
I have the tools and firmware, but i can't get the tablet into recovery. It shows up in device manager now, but under disks as TABEO device. It just won't get to the point i can ADB into recovery and the reset button won't force it into recovery.
2012/12/25
17:13
Forum Posts: 2028
Archos 101 XS
On the arnova childpad which is almost the same like the 7dg3, the combinations is
: insert a paperclip in the Reset pinhole of the tablet and press the Power button
There is another way to get in the bootloader, get the tablet in the android recovery mode (the image with a green android) it is usually achieved by pressing power button and volume key – in the same time, the tablet must be off to get in this state, then you need to connect the tablet to the pc. A pop up will appear regarding installation of the drivers, i use superoneclick to force install them. After the installation in adb i issue the command adb devices to see if the device is connected adb reboot bootloader to get the tablet in the flashing mode.
2012/12/25
17:28
Forum Posts: 2028
Archos 101 XS
C:\Android\android-sdk\platform-tools>adb devices
List of devices attached
0123456789ABCDEF        recovery
C:\Android\android-sdk\platform-tools>adb reboot bootloader
2012/12/25
22:48
captmeach7
The button combinations werent working, im guessing because it's just different enough to be annoying. I also have the Android SDK installed and couldn't get it to register on the PC because it wouldn't boot far enough for ADB to see it. Also there is no volume button, only power and reset….BUT……
I opened it up, and there is a button on the inside. I used this and the power button, while hitting reset and it installed as a Vimicro superdrive disk. VDrf. So now im trying to use MPtool to reflash the original firmware as per the instructions for some of the other Vortex generic tablets.
2013/02/15
16:14
Richardsonke
@captmeach7, did you get it to flash the firmware after it mounted as a "vimicro superdrive disk"?  I'm curious if I can flash a 7d g3 firmware to it.  Is the third button that you have to press inside of the device?  Did you have to break any warranty stickers or anything?  Thanks!
-Keith
2013/02/15
19:01
captmeach7
I did get the G3 firmware flashed to it. The button is on the inside,but there was no warranty sticker. The screws to get inside the device were plain silver phillips screws. I have a couple photos of the inside with the button somewhere. I had to use a pc with Windows XP installed for MPtool to work, and if i recall it tells me the flash failed even though the tablet will boot after a couple of tries.
2013/02/15
19:05
Richardsonke
Thanks for responding.  Did you use the firmware linked to by globula_neagra?  Did the rockchip flashing tool not work?  Thanks again!
2013/03/19
23:52
Mewantfirmware
Arnova ChildPad
Hi. How did you flash it? I got the vdfu drive up, but can't find the MPtool software here or on other sites.
Most Users Ever Online: 646
Currently Online: admin, jajonesss, újszülött, Runner68, JochenKauz, Gruber, Sylvania, zgf1, royd, delux, fr-fr, furonai, loka, Jdemon, francodi, Brnky, buzz360, santolito, M.Moe, DarthJabba, tornicess, theostill, ebeb2 U30GT2, IsolatedAbyss, fini29, antliesdim, Larseng, Meewind, netzotov, hbbz, iheehioe, wasseruhr, traysub, xfera91, validatus, chickencubes, anonyme1686, xadaya, idiot, main3dtv, velly, flexer, masito1969, rpells, andreveeguil, gander, longest, dannylingus@hotmail.com, cybro, jeantrevor, harunurah, sashastar, Impulsion, ericaruthshaw, JTRO, sapeco
288 Guest(s)
admin: 3933
globula_neagra: 2028
Guest Posters: 39
Members: 82794
Forums: 132
Topics: 2983
Newest Members: ole23, sapeco, nikevdxnyy, QQfiPhLNqp, JTRO, joehung
Moderators: HaroldG (117), globula_neagra (2028), exelletor (344)
Administrators: admin (3933)
