NEOCM10 "LEON" Jelly Bean Rom *Testing*
neomode
Forum Posts: 26
Thanks Received: 15
2012/09/28 - 21:59
This is a CM10 a.k.a Jelly Bean Rom Build from Source.
The Rom has CWM Recovery.
Please Test it and give me Feedback.
Feature:
Apex Launcher
Google+
Google Talk
YouTube
Google Mail
Google Now
Working:
Seems all is Working, Feedback Please.
Not Working:
You Tell Me
Installation:
1.: Download the ROM here
http://d-h.st/users/neomode/neocm10.zip
1a: Kernel for Childpad Resitive here
http://d-h.st/Fcb
No Mirrors Please !!
2.: Unpack it
3.: Change to RKAndroid_v1.29
4.: Run "RKAndroidTool" as Admin
5.: Check Loader and Press EraseIDB
6.: Uncheck Loader and Press Run (For CP Resitive Owners change the Kernel to the Kernel Image for the Childpad Resitive)
7.: When Finishd the ROM will Restart in the CWM Recovery
8.: Reboot Now
9.: Starting Up wait 5 Min and Reboot Again
10.: Have Fun
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/09/29 - 00:07
Pretty cool actually. Still, same comments as for the CM9:
- The CWM Recovery didn't do much with my touch-input, maybe you could give the one from my ROM a try?
- The G-Sensor is not doing much either… No idea what is wrong with it here…
- Volume buttons?
neomode
Forum Posts: 26
Thanks Received: 15
2012/09/29 - 00:16
Thank You !
- Let me know where I can get Your CWM Please.
- I know the Problem with the G-Sensor , i will try to Fix it. So long Turn the Automatic Rotation Off.
- First i will Fix the Volumen Buttons for the NEOCM9 than the for the NEOCM10
Kind Regards
Rainer
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/09/29 - 00:32
I uploaded the Prestigio recovery(you can check out my 4.0.4 ROM here) at arctablet server:
http://exelletor.arctablet.com/recovery-cwm.img
Actually, just a few hours before you released your ROM, I started playing with another JellyBean ROM for the ChildPad and well, while it was hardly usable(on the 8c G3 it worked better, but there are kernel problems with it), the G-sensor was one of the thigns that was working there... So maybe we could cooperate and could release a hybride ROM with two of us?
neomode
Forum Posts: 26
Thanks Received: 15
2012/09/29 - 00:38
Thank´s for Uploading your Recovery !!
Yes we can do it, try Your Rom with my Kernel so we will see if it is a Kernel Bug :-)
And Sorry for my Englisch im from Germany ;-)
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/09/30 - 20:51
BTW, here are the parameter files so there is also space left for userdata etc.
http://exelletor.arctablet.com/parameter.zip
You need to format it first on JB.
I don't know how much the system partition exactly is, but your ROM fits on it. Wink
88cavalierz24
2012/10/03 - 09:38
just flashed this with the resistive kernal and my touch inputs are all over, the closer to the center the closer they are, but the further away its reading the input as a mirror so i can touch the top of the screen and it presses home(bottom). Trying to see if i can calibrate the screen but havent found that option yet.
Thanks Received: 3169
2012/10/03 - 10:27
I don't think using the default kernel is enough to add support for your resistive screen. You'll probably need to get the calibration apk from your original system and copy it to /system/app on the NeoCM10 firmware.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/10/06 - 14:29
It's coming...
Image Enlarger
Image Enlarger
Image Enlarger
The following users say thank you to exelletor for this useful post:
admin, bdejonck, Oma7144
b.breum
Forum Posts: 91
Thanks Received: 12
2012/10/07 - 19:10
uhh looks promising... i can hardly wait ;)
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/10/14 - 00:36
Speaking about JellyBean performance:
AN7DG3Bench.jpgImage Enlarger
(stock resistive did 2167 back in June, that's ~35% increase)
Thanks goes to Oma, ChildPad version of the ROM is going to be published in the coming days.
sp_PlupAttachments Attachments
b.breum
b.breum
Forum Posts: 91
Thanks Received: 12
2012/10/14 - 07:18
hows the g sensor working?
Is it with the updated kernel from the official release?
I am guessing that you guys have worked a bit more on it since its first release so would be interesting to know what has changed if any?
Still looking forward and GOOD WORK!
edit: Got inspired by the performance test
Im running the first release with google play enabled on a capasitive childpad
my score is 2210
cpu 712
gpu 866
ram 397
io 235
cpu freq 912
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/10/14 - 11:20
Yes, it's with the last kernel version I am aware of. Basically, this ROM is just a cleaned-up ext4 OMA ROM made to work on the ChildPad. The battery status and g-sensor are both working. It was also quite a big task to bring back the volume buttons. The thing that is not working is USB Debugging and camera image is mirrored. I will have a look on this when I have some more free time, in a week or so...
Thanks Received: 264
2012/10/14 - 12:24
on the 7c g3, when you unpack the boot.img,you will end up with one folder and 1 file, the zimage. and the ramdisk.
in the ramdisk are all the stuff that makes the tablet to work. (beside de kernel)
for example i found a rusian model of the arnova 7c g3, and same thing, no usb/adb working so i unpacked the boot.img, and i copied from the old boot.img the adb which is in sbin folder, then i copied also the file init.qcom.usb.rc that is ramdisk, which is in the ramdisk folder.
the init.qcom.usb.rc defines how the tablet is recognized in different moments when is connected to the pc. (usb debugg/mass storage/fastboot)
the system should be the same also for the other tablets, you only need to find out where is the ramdisk :D because from what i saw, usually you get only the kernel image when you flash some roms for this tablet.
Thanks Received: 1374
2012/10/14 - 13:45
Device ID's are defined in init.rk29board.usb.rc, which is in boot.img.
I use the standard:
adb - 2207:0006
mtp - 2207:0001
mass storage - 2207:0000
PS can boot this on Odys-Loox - works fine ;-)
Childtab1-1.pngImage EnlargerChildtab3-2.pngImage EnlargerChildtab2-1.pngImage EnlargerChildtab4-1.pngImage Enlarger
Currently Online: JSun
136 Guest(s)
Devices in use: Desktop (107), Phone (27), Tablet (3)
hacktes
Walldos
MOUNIR 1923
cynthiavd
rafi462
PillowMan
Topics: 6010
Members: 260639
