After a few failed tries, you are usually offered to use your Google password to unlock. If that all fails, the best option is probably to reflash a firmware, all data on the tablet will be erased.
Alternative install procedure
Before starting, please make sure you backup all your existing apps, data and files that are on your tablet as they will be erased during the flash process. Also make sure your device is charged for more than 35% and is still charging via usb.
Step 1. Download Firmware
Choose one of the two firmwares from the custom firmware download section below, depending on what type of touchscreen your ChildPad has and extract the custom firmware image (update.img) on your computer hard drive.
Step 2. Install and run Rockchip Flashing tool
Please follow the Rockchip Flashing tool procedure: that will explain how to download Rockchip flashing tool, unpack the archive, put your device into flashing mode and flash the custom firmware file that you have unpacked in Step 1.
Step 3. Arnova ChildPad flashing and restart
After Rockchip flasher has transferred the custom firmware to the tablet, the device will restart and install the firmware. Finally, you will be back to Arnova default startup wizard.
You will find the 3 easy steps of the installation procedure in the following video, see how to get Google Play and root to your Arnova ChildPad in less than 10 minutes(video shows flashing an Arnova 10b G3, the flashing method for the ChildPad is the same) .
Which is part of this
http://www.arctablet.com/blog/featured/arnova-childpad-custom-firmware-google-play-root/ and looks very understadble to me.
109 Guest(s)
Devices in use: Desktop (94), Phone (15)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
