this is the one from the 7c g3
http://pastebin.com/wSQ7P0f4
New things
ro.config.ehrpd=true
this setting is for data connection via 3g, and enables the usage of the LTE antenas
debug.enabletr=false
This is an option that helps to solve to problem withe fc on the menu
you can add it on your rom 🙂
150.ro.screen.layout=large
when i play with this setting, all the things change on my tablet (the size of the icons, more icons are available)
here is more info about it http://developer.android.com/guide/practices/screens_support.html
try ro.screen.layout=normal
and set the density to 140-160
2012/11/20
robwilsonirl said
HiCould someone explain how I do the "adb push" ?
Tia
Rob
In CMD command on PC. You need to unpack adb files in the root of any disk, for example disk C:adb and place the file Trebuchet.apk in the root of disk C: too. Then click "Start -> Run -> cmd -> cd c:adb -> adb push C:Trebuchet.apk /system/app/Trebuchet.apk".
You need to have this files on PC:
#:adbadb.exe
#:adbAdbWinApi.dll
#:adbAdbWinUsbApi.dll
#:adbfastboot.exe
The following users say thank you to Dlinniy for this useful post:
globula_neagraMost Users Ever Online: 803
78 Guest(s)
Devices in use: Desktop (66), Phone (12)
hans41
rickybk
soniya07
ironmangitar
