Impossible to get recovery mode
evidentrasta
2013/02/22 - 12:07
Probleme with childpad ( Big Buck Bunny edition )
Impossible to get recovery mode !!!
help me please !!!
when usb connect to computer allways reboot ( impossible to make childpad off )
i have tried to connect usb cable after reset but allways ARNOVA & childPAD screen :(
Thanks Received: 268
2013/02/22 - 17:09
If the device reboots like that, it means that actually you don`t get it in flashing mode, re-read how to get the tablet in flashing mode
If you still don`t manage, try to use adb with the command
adb reboot bootloader --->>>> you can use use this only if your tablet is booting up fine.
evidentrasta
2013/02/22 - 17:41
sorry but I do not understand.
In the doc to flash it says turn the power off, but if the cable are connected to the computer restarts childpad all alone!
Impossible to have flashing mode.
sorry for my english but I'm french
largewoodenspoon
2013/02/23 - 19:23
same issue - please help!!!!!!!!!
2013/02/23 - 19:53
Try to get the tablet in flashing mode without having it connected to the pc or any power source, do all the step like in the tutorial, and then connect it to the pc.
largewoodenspoon
2013/02/23 - 20:47
tried that
soon as it plugs into pc - it boots up
no recovery mode
really need an exact step by step!!!
largewoodenspoon
2013/02/24 - 11:06
this is driving me crazy!
also tried adb reboot bootloader command
just boots right up as normal!?!?!?!
pppllleeeaaassseeeee somebody help me with a step by step
also - my led lights are red/blue and not red/green - is this normal???
2013/02/24 - 11:41
using the adb reboot bootloader involves having the device working or in android recovery mode (dead android with exclamation mark)
having android sdk, or at least some modules from it
having the adb drivers installed
if you just type adb reboot bootloader randomly it will not work.
largewoodenspoon
2013/02/24 - 11:51
hi there
i have  android sdk, or at least some modules from it
and the adb drivers installed
it connects fine and communicates ok but like i said it is refusing to get into flashing mode whatever i do
really need some help
2013/02/24 - 11:54
well i did suggested you all the options, wait, maybe admin will bring more input on your situation.
largewoodenspoon
2013/02/24 - 11:57
really appreciate your advice
have tried pin reset - but like i said the tablet powers on right away connected to usb
same when tried to get to recovery with no usb - soon as it gets plugged in it powers up
am totally stuck - but i know people have done this
greekpow
2013/03/08 - 23:00
i have exactly the same problem. It is impossible to shut down the tablet with the usb in. It always do restart instead of shut down. Is it possible they changed something on the newer childpads? I had one older and i flashed it with no problem.
Please help
largewoodenspoon
2013/03/09 - 11:30
that was my point exactly!
they must have changed something!?
Mewantfirmware
Forum Posts: 14
2013/03/20 - 11:25
I have the exact same problem. Reset + Power does nothing except reboot the device (with or without USB cable), "adb reboot recovery" just does a normal reboot.
Using the internal button, I got the VDfu drive up (topic), but don't know what to do with it.
ArcTools doesn't show a firmware for it either.
The device is AN7DG3B, Android 4.0.3, build 2012.12.13 1.07.
Any help at all would be greatly appreciated.
largewoodenspoon
2013/03/20 - 13:03
whats the internal button?
77 Guest(s)
Devices in use: Desktop (72), Phone (5)
