CP Model/ FW Compatibility
Zentaur71
31
2013/02/05 - 13:02
so... the reply is working.
i mixed the original FW parameters to the custom one and get 2.05 GB of total Memory.!!!
wifi and touchscreen is working fine. The childpad is the one without Alvin branding.
the filesize is to big...   i do not know how i can upload the file.
but if you use the Alvin FW and unpack it with IMGETOOLS and use the kasty 50f-2g and do also.
change out the parameter from 50f-2g with them from Alvin and pack it again with imagetools.
you got a file update_new.img  ... rename it to update and use RKbatch tools to flash the childpad.
ftp://support.arnovatech.com/G3%20Android%20tablet/     2918 device PC tools.zip there you find the programm.
the Alvin FW is suppoted on ARNOVA HOME PAGE.
good luck
Currently Online: ri9000
71 Guest(s)
Devices in use: Desktop (66), Phone (6)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
