2012/11/26
Frankly speaking, I feel a little bit confused...
If I've understood well, there are now several ChildPad models across the Europe, with sensitive HW differences.....
For that reason, not all the FW upgrades work in the right way...
And, reading all the posts (thanks all for the precious infos), it's really hard to sort out which FW/model combination works well (because some fundamental details are missing)...
And, probably, the developers too are in the same situation...
So, my suggestion is, like many other forums/devices, to start a thread where to write down:
1. which model you have
2. which Firmware(s) you've tried and which issues you have noticed
I think that users can understand better which FW is better to install and which one to test and developers can get precious infos about users/devices for further collaboration/support.
Morph.
The following users say thank you to morpheus883 for this useful post:
admin, PrinzPoldi007, medeni73, stevedeeThanks for the initiative, that will hopefully help users to update their devices more easily.Â
For point 2, please specify the filename and url of the firmware(s) tried.
morpheus883 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/12/04
CP Ref. 502153. Capacitive
FW: http://www.arctablet.com/blog/downloads/firmware/ArnovaChildPad/kasty-arnchilpadc-40-050c-1G.zip
Flashed with http://www.arctablet.com/blog/downloads/tools/Firmware/Rockchip_CPU_based/Rockchip_Batch_Tool_v1.5.zip, following this http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/Â description.
Flashing method: "restore" not "upgrade"
Working good, the only "problem" I have: Booting very slowly (approx. 50 seconds), but I don't know, how long the CP boots with the regular FW, because after unpacking and checking if it works I immediately flashed the Custom FW to get access to the playstore.
The following users say thank you to PrinzPoldi007 for this useful post:
morpheus883, nickep
2012/11/30
I hope this thread will be pinned and become true source for all troublesome firmwares and different models of Childpad...
One question though: what should we write as model info and where do we find exactly that info cos I saw on back of my Childpad that there are many different numbers and codes....
I don’t think that the reference number which is actual the model number.
For example if you type in Google ref 502153 arnova, the childpad will appear.
What i found on the 7c g3, there is a lot of tablets around the number 1300 which have a different touch screen them mine which is the 373 tablet produced.
This number is on the box, under the ref number, mine is FD122000373, on another person who has the FD122001310 the touch screen was different.
I think you should concentrate in finding devices that are closer to your FD number to create an exact image of the touch screens installed in each device. I am sure that if some of you would write here the FD number you will see difference, and I suspect the same issue as on the 7cg3, after the first 1000 units the touch screen was changed.
medeni73, morpheus883
2012/11/30
My turn now
ChildPad bought couple of days ago in Germany
Ref 502153
Under is not FD but SC number (no FD number on box nor on Pad) : SC 124304014
All firmwares were installed without any problems BUT touch function doesnt work on:
Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware
Arnova ChildPad&7d G3 Android 4.0.4 + CWM Recovery custom firmware
NEOCM10 Version 1.25 from FreakPad http://d-h.st/qsp
Touch function DOES work with test file Arnova ChildPad capacitive test firmware from official 09/26
So it seems to me that all newer models need to have newer kernel in order to work...So IÂ hope that this test firmware could be good base for making full custom firmware
The following users say thank you to medeni73 for this useful post:
morpheus883
well the sc must the the equivelent of the fd from my tablet.
2012/11/26
My contribute:
ChildPad bought a couple of weeks ago in Italy
Ref: 502153
P/N:Â Child Pad Capacitive 4GB EU (No Alvin extras)
S/N:Â SC 124305670
It works well with official 09/26 update and test fw built on that.
I haven't tried (yet)Â NEOCM10 Version 1.25Â fw.
Probably, this fw contains or newer drivers or some specific scripts for new capacitive modelsÂ
2012/12/16
I cannot download the Firmware from:
there appears a site with the text:
Security error(6)
error logged, system administrator has been notified
Has anyone this problem too?
Greets
Steffen
kasty-arnchilpadc-40-050c-1G.zip file has been removed and replaced by a newer update, see here:
2012/12/02
Ref: 502170
UK model, big buck bunny
Capacitive screen
working firmware: kasty-arnchilpadc-40-050d-2G, wifi works fine
non working firmware: kasty-arnchilpadc-40-050f-2G...............no wifi, so had to go back to kasty-arnchilpadc-40-050f-2G, even thou this was a wifi fix firmware for some, not for me.
Currently Online: andreive
69 Guest(s)
Devices in use: Desktop (61), Phone (9)
hans41
rickybk
soniya07
ironmangitar
