CHILDPAD VIMICRO AN7DG3B
firmware+ flashing tools
LOT75
Thanks Received: 7
2014/07/09 - 02:58
After three months  i discover that my childpad frozen on boot is not rockchip tablet but Vimicro, so i need the custom firmware and flashing tools for this kind of tablet.
Thank you in advance.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2014/07/09 - 14:16
Unfortunately there is no firmware available for the Vimicro version of the ChildPad, you can refer to this forum topic here:
http://www.arctablet.com/blog/forum/archos-arnova-childpad/tabeo7dg3-cant-get-into-recovery-mode/page-4/
I recommend you to contact Arnova or Tabeo support asking for the stock firmware...
LOT75
Thanks Received: 7
2014/10/19 - 18:19
After many months of researches and contacts, I finally found the recovery tools of the Vimicro CHILDPAD tablet and gave her life another time.
Note: to install GOGLE PLAY you have to:
1) Root the tablet with "KingRoot"
2) Follow up the steps presents in this video:
The following users say thank you to LOT75 for this useful post:
fkruis, nunoit, reten, yesuha
fkruis
2014/10/19 - 20:50
Hello Lot75,
thanks for the firmware.
Only i do not speak french.
can you explain to me how to flash the firmware. My childpad is in a not working state.
greetings,
fkruis
nunoit
Forum Posts: 12
2014/10/20 - 16:32
recovery tool not working for me can you post a step by step of how you did flash device and any special cables you may have used. my device had usb socked force ably removed i re-soldered and now played with some but all along its in a boot loop when plugged into laptop.  running win 7 on this laptop. i am thinking that the flash chip may have to be programmed directly not sure yet.
LOT75
Thanks Received: 7
2014/10/21 - 00:07
Hello fkruis and nunoit,
you will find in attachment a document that explain how to flash the firmware that I shared.
I would like to precise that the method of flashing and the firmware concern only the ChildPad whose reference is  AN7DG3B  (I hope that you have understood what I mean)
If after this explanation you still have a problem to flash your tablet, please, before asking me anything,  give me the reference of your tablet.
fkruis, nunoit
nunoit
Forum Posts: 12
2014/10/21 - 16:56
my tablet has the following info
ARNOVA | 7K G3
MODEL# AN7DG3C
FCC:ID SOVAN7DG3C
its not listed as the child pad but it looks identical externally and internally to the child pad other than the logo on the cover.
i just tried this update with my laptop running win 7 no luck could be laptop. what operating system are you using windows xp, vista, 7, ?.  i am looking at the possibility that the os makes a difference.
LOT75
Thanks Received: 7
2014/10/25 - 13:25
Hello nunoit,
I don't have big idea about this model AN7DG3C, but are you sure that your tablet is vimicro not rockchip childpad? If you are sure, the MPtool must recognize your device and you have to repeat correctly the steps shown is the word file that i shared (use the original usb cable, if you loss it try with Samsung ones)
My tablet is recolonized us VDfu storage device  by vista and win 7 OS.
nunoit
fkruis
2014/10/25 - 14:18
Hello Lot75,
i tried the firmware and the result is a working childpad   Thanks.
the only problem i have is that the alignment of the screen is  now one centimeter to the right.
so i have a black vertical bar on the left.
any idea who toi solve this ?
The following users say thank you to fkruis for this useful post:
nunoit
nunoit
Forum Posts: 12
2014/10/25 - 16:51
i am certian the it is a vimicro chipset (vc0882bxsa)is the number printed on chip.right now this computer does not recognize the device in any way. i will try with a differant computer and post results later on. thanks
momen.helal
2014/11/09 - 13:30
i flashed my 502140 with boot and same issuse in screen alignment
Jeffless Bone
2014/12/02 - 17:46
hello,
i need help with my Arnova Childpad (Vimicro Model). It doesnt boot up anymore, but remains at the ARNOVA boot screen. I want to flash or reset firmware.
I can connect it to the pc and make it being recognized as a special drive by using the internal button. But then, what do i have to do?
Can someone please help me out with a step by step explanation on how i can flash the firmware. Also where can i find the software that i need ( including mptool ) ? Confused
nunoit
Forum Posts: 12
2014/12/03 - 21:08
sorry thought i had a link
Jeffless Bone
2014/12/03 - 22:29
Jeffless Bone said
hello,
EDIT---
ok, i was able to flash my childpad now using MPTOOL and the firmware given by -LOT75- .
So at least the tablet boots up again. Problem is, as others mentioned here, the screen alignment. And the orientation sensor isnt working correctly, means screen is turned around by 180 degrees...
anyone knows a better solution or how to fix those screen issues?
nunoit
Forum Posts: 12
2014/12/04 - 19:58
sorry jeffless bone but can you post the file and program and maybe a method you used my tablet is frozen like yours was. and what version of windows are you using.
77 Guest(s)
Devices in use: Desktop (71), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
