Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware
nitramk
76
2013/01/15 - 12:00
just choose the appropriate image files and the offset is set automatically
slupz
Forum Posts: 20
77
2013/01/15 - 12:38
ok now with the other kernel JB works, but as I said on the wifi does not work.
I can not extract the kernel from the file 50g update.img I tried to mount it on ubuntu with furius but wrong.
can you help me?
thanks
medeni73
Forum Posts: 51
Thanks Received: 8
78
2013/01/15 - 13:02
Download Rk29xx ImageTools V2.1 from here https://docs.google.com/leaf?id=0B8hUXYDeoy_hNTc1YTVkYTMtNTNjZS00YjI2LTgyNDYtYjRjZjFmODdiZTQ1
Usage:
1. Download the tool and unzip into a folder
2. copy the image file into this folder,and rename to wendal.img
3. double click Runme.bat
4. choose unpack and wait
tool creates new folder Temp and there you will found extracted kernel file from 50g update.img
slupz
Forum Posts: 20
79
2013/01/15 - 13:43
thank you very much for your patience, though even with the 50g version of the kernel does not work on wifi Cry
medeni73
Forum Posts: 51
Thanks Received: 8
80
2013/01/15 - 14:02
sorry to hear that. I'm afraid I cant help you further cos I have different model that has no problems with Wifi...
You could always try to extract kernel from other versions of firmware and maybe you will get lucky ;)
also read this topic through http://www.arctablet.com/blog/forum/archos-arnova-childpad/wlan-problem-with-childpad-after-flashing/
slupz
Forum Posts: 20
81
2013/01/15 - 14:07
my version is:
my childpad is capacitive 4GB EU
502153
your?
I was trying to extract the images of the system, because I noticed that just does not load the device, that you can not see the mac address of the wifi, so maybe does not load the right modules, but I do not extract individual images
medeni73
Forum Posts: 51
Thanks Received: 8
82
2013/01/15 - 14:10
I have also capacitive model from EU ref. 502153 but this ref. number is not that important cos there are different models with same ref. number. My model has SC number 124304014.
Other part of your post with extracting I didnt understand sorry
slupz
Forum Posts: 20
83
2013/01/15 - 14:14
my SC is 124713325
excuse my bad English
I want to extract the kernel and system to try to understand why there is wifi
medeni73
Forum Posts: 51
Thanks Received: 8
84
2013/01/15 - 14:22
I would say that your wifi problem lies in kernel file and not in system one...
Anyhow I would suggest to wait for admins that have more technical knowledge to maybe help you further...
The following users say thank you to medeni73 for this useful post:
slupz
slupz
Forum Posts: 20
85
2013/01/15 - 14:25
ok okay meanwhile thanks and wait for some administrators give me some advice
slupz
Forum Posts: 20
86
2013/01/15 - 15:40
I was able to mount the image system
I noticed that the module wlan.ko is different between the two images, I tried to change it but it's still not
zaxarop
87
2013/01/17 - 09:50
I have a big problem.
After i finish the install via EvolutionRKtool start boot but freeze at the welcome screen. No tats working, Can anyone help me?
medeni73
Forum Posts: 51
Thanks Received: 8
88
2013/01/17 - 11:08
First boot after flashing takes more time as usual so you may wait a bit longer. What doesnt work "no tats" ????
If you have problem with touch screen then you need to replace kernel file from JB4.1 package with other one from here for example http://zarth.de/kernel.img
slupz
Forum Posts: 20
89
2013/01/21 - 10:22
compare the hardware?
my dmesg is
Download dmesg.txtDownload dmesg.txt
-ctr-
90
2013/03/31 - 13:09
There seems to be an embedded Trojan in that package, so please beware:
https://www.virustotal.com/en/file/c50e7b23fd605bd6a768980492e75bbbaaf7d80272e9b9cd0fc6429585c1297b/analysis/1364727981/
Rockchip v1.5 tools doesnt have the same kind of detection, so it is not related to the behaviour of the tool!
52 Guest(s)
Devices in use: Desktop (46), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
