Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware
slupz
Forum Posts: 20
61
2013/01/10 - 11:06
hi,
I tried to load JB but at the end of the procedure stops with the first screen, who managed to make it work with childpad is kind enough to write well with the procedure and that file did you use?
because I do not understand how to get into cwm and install the fix.
I would be grateful
thanks
nitramk
62
2013/01/10 - 16:02
In my case i followed the step by step guide. The only thing i had to do is to choose the image files within the flashing tool manuelly as they where not found automatically.
slupz
Forum Posts: 20
63
2013/01/14 - 12:59
then it worked?
my childpad is capacitive 4GB EU
502153 and you?
neojoe666
64
2013/01/14 - 13:29
my kid got the childpad for Christmas. I wanted to flash it and got the same problem as other on this forum : the touch screen doens't work anymore.
I tried with the firmware 4.1.1 and 4.0.4 and I faced the same issue.
Is there any other version which could allow me to install google play on this pad ?
Dolby
Forum Posts: 64
65
2013/01/14 - 20:28
Hello i have flashed the 2x Arnova 7D G3 with 4GB with the Arnova Childpad-AN7DG3-CP20120919EV2.3 This works great my kids have now 1,5GB apps storage to install games. My kids are very happy with it. Now my kids has also the Alvin childpad.
I tried before this flash:
1. the Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware en the
2. Arnova7Dtablet-kasty-arnchilpadc-40-050f-2G-.
But with those the arnova 7D G3 doesn't react on the touchscreen. After that i flashed the Childpad-AN7DG3-CP20120919EV2.3 this works greet.
Thanx for the image. I hopen on the future the new version 4.1.1. JB wil also work on the Arnova 7D G3.
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
medeni73
Forum Posts: 51
Thanks Received: 8
66
2013/01/15 - 09:13
I dont have Arnova 7D G3 but I think you need another kernel in order to get those to Firmwares to work. Try Arnova7Dtablet-kasty-arnchilpadc-40-050g-2G- and Arnova7Dtablet-kasty-arnchilpadc-40-050d-2G- versions of firmware and maybe you will get your tablet to work.
Can you be more specific about problem with sd card??? What doesnt work???
neojoe666
67
2013/01/15 - 09:46
After reading some posts on this forum, I installed the kasty firmware 50g and it works fine.
Thanks everyone !
slupz
Forum Posts: 20
68
2013/01/15 - 09:50
is the firmware 50g works
but someone has managed to get JB?
medeni73
Forum Posts: 51
Thanks Received: 8
69
2013/01/15 - 10:48
JB works without problems for those with newer models only i you change kernel file from package and replace it with this one http://zarth.de/kernel.img
Touch functionality problems should go away but some users had problems with wifi. If you have problems with wifi then you need to extract kernel from kasty firmware 50g and put it in JB package instead of original kernel file...
slupz
Forum Posts: 20
70
2013/01/15 - 10:51
I'm sorry, you could write the exact steps, because I've tried several but all with negative results.
I would be really grateful
thanks
medeni73
Forum Posts: 51
Thanks Received: 8
71
2013/01/15 - 11:27
How bout you telling us what steps did you make wrong? what negative results? be point specific please and then you get specific answer. and please read oder forum topics...step by step tutorials are getting repeated every time someone new comes in here and doesnt want to read a bit through but want to get it served on a plate...
slupz
Forum Posts: 20
72
2013/01/15 - 11:36
you're right, I beg your pardon.
then I tried the firmware
http://www.arctablet.com/blog/featured/arnova-childpad-custom-firmware-google-play-root/
http://www.arctablet.com/blog/featured/arnova-childpad7d-g3-capacitive-android-4-1-1-jb-custom-firmware/
the touchscreen does not work, then reading in the forum I loaded the 50g version, the one I have now is in childpad everything works, but I would like to load JB.
thanks
neojoe666
73
2013/01/15 - 11:39
So, try this one :
and before updating your childpad, replace the kernel with this one :
slupz
Forum Posts: 20
74
2013/01/15 - 11:43
ok thanks now I feel now, but just a question, the offset must be like in the link you put? because when I open the program, the fields are empty
thanks
medeni73
Forum Posts: 51
Thanks Received: 8
75
2013/01/15 - 11:57
You must check all fields except for Loader and Backup. If fields are empty then you must click on every single "..." and choose those files manually (look in picture what and where are those files). I think offset values will be automatically filled in when you select some file. Just dont forget to pick kernel.img from other source and not that file that comes with JB package
77 Guest(s)
Devices in use: Desktop (73), Phone (3), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
