Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware
jojosh00
31
2012/11/10 - 20:11
Hello
Thanks you for this awesome custom FW. I successfully install it today without any problems.... Except for latest Angry Birds Star Wars which does not want to start on this platform (black screen on startup, then jump back to the desktop)... Has anyone experienced the same problem ?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
32
2012/11/10 - 23:40
Angry Birds Starwars doesn't work on RK2918 tablets...
The following users say thank you to exelletor for this useful post:
b.breum
jojosh00
33
2012/11/11 - 08:39
Thank you for your quick answer Exelletor ...
Damn... That's pretty bad...
I've send a support request on Rovio's site to ask them if they have some plans to have it work on it... So far, all their other titles have been working pretty well...
Keep up the good work with your custom FWs... They are much appreciated !
b.breum
Forum Posts: 91
Thanks Received: 12
34
2012/11/11 - 20:15
Finally had the time to update it to JB
BUT
I ran into some problems. I had to download it 4 times to get one that didnt have fault in it.. Thats strange but not your problem.
then doint as i did with 4.0.4 all went smooth but the pad just didnt reboot.
Several tries later i also tried to flash loader and then it worked
touch screen no problems.
Find it strange that it doesnt write as much to the under rkandroid tool as it can?
See
writing data to flash size (460172)K, Written (459740)K
and
checking download data size (460172)K, Written (459740)K
is that normal?
Anyway it has now been up and running for 25 minutes ;)
again thank you for all your work!!
siro
35
2012/11/12 - 00:04
I have a new device with its original system.
Should I first install the original root firmware, and then upgrade it to this version, or can I go ahead directly to this one?
b.breum
Forum Posts: 91
Thanks Received: 12
36
2012/11/12 - 08:41
go ahead with this one.
But Be aware that there are problems with the touchscreen
nikgl
37
2012/11/12 - 09:32
This is not true. Most of the people have no problem at all with the touch screen.
b.breum
Forum Posts: 91
Thanks Received: 12
38
2012/11/12 - 12:20
i should have refrased.
Some people and it seems to be ones who recently have bought a childpad, do experiense problems with the upgrade.
Better now?
Cool
The following users say thank you to b.breum for this useful post:
nikgl
b.breum
Forum Posts: 91
Thanks Received: 12
39
2012/11/15 - 09:41
After a couple of days of having fun with it. i have experience multiple freezes of it, when it is to wake from standby.
I have reformated the sd card and also tried without with same result. after a longer period of time of no use it wont wake from standby - get passed the unlock screen.
I'll now try with the other jb version and let you know of the results
i do have the antutu test score
total 2816
cpu 707
gpu 1165
ram 384
io 560
vandrommethomas
40
2012/11/21 - 21:10
news yet on the not-working-touchscreen? Still have an unworking touchscreen on a recent capacitive version (Ref. 502172). I only get the Childpad back to work with the original firmware and don't have the preinstalled apps anymore. So for the moment, it's useless :-(
vandrommethomas
41
2012/11/21 - 21:23
I Found on the Arnova site that the latest (and only) firmware is:
ARNOVA ChildPad Capacitive
Firmware changes
Version 1.0 - September 26th, 2012
  • Home screen: Fix short-cuts or widgets added to the home screen disappearing after power-off of the device
However, you seem to have been used some previous version:
Main features:
  • Android 4.1.1 built from Oma JB v1.2.2
  • System in ext4 format
  • CWM Touch Recovery built from Prestigio 5080B
  • Firmware files from 20120608 Official FW version
Any solution here?
Kind Regards
Thanks Received: 3171
42
2012/11/21 - 21:58
vandrommethomas
dcima
43
2012/12/06 - 12:24
Spending some hours because of driver setup. I forgot my headphone connect to PC and can't hear the sound of driver initialization after 15 secs. So i tried hard reset many times with and without push power on button.
I got many times an Android image with a red triangle and esclamation mark; finally i read on this forum that it was a wrong recovery mode and that the right one was a beep on PC when Windows 7 tried to install a new driver.
After that and reformatting SD, everything works perfectly. It's absolutely fast then 4.0.4, full access to Play Store ... face recognition! GREAT JOB!
Just some questions: it'is possible add an Internet pass-thru mode/service? And an external mass-storage (usb disk) ? Mouse ? It works perfectly with a usb keyboard ... Wink
thanks!
diego
b.breum
Forum Posts: 91
Thanks Received: 12
44
2012/12/07 - 11:07
exelletor said
For now, I can't say when the updated version will come. Currently this cfw still comes with that silly old kernel from June, because I can't get the new, september one, to run on JB...
Speaking of Chainfire, I will have a look, but can't promise anything...
Chainfire wont work on any JB device.... sadly
t23
Forum Posts: 27
45
2012/12/07 - 12:24
Anyone got any idea how to get USB debugging to work? I tried both sneaking the right driver in, plus the one that actually matches the USB device ID that this firmware presents, but neither work.
Also, i got the wifi working after reflashing four times. Don't know what's up with that.
76 Guest(s)
Devices in use: Desktop (69), Phone (6), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
