There was a small problem with the link, it's fixed now.
2012/10/21
wprata said
I have done the firmware upgrade and all went well.
But now, Applications do not have access to SD Card. I can get there with the bulit-In explorer, but any applications that access the SD Card complaints saying “No External Storage Available”!
Any help?Regards,
WPrata
After formatting the SD Card, all was okay.
Thanks to the developers for the excelent work on porting 4.1 to Childpad.
Great work
Best regards,
WP
2012/07/28
Better battery, now that sounds interesting.
Have you had a chance to look at the new firmware to see if there is any changes in the kernel.. I plan on updating it to this version tonight unless you say that a new version with update is on the way shortly.
Either way its still amazing work!
2012/10/24
hello very nice guide! ive successfully installed the firmware and its very smooth! thanks to guys. one thing, my problem is about installing Chainfire 3d, the app works well but when i downloaded the CF3D Driver it reboots then few seconds it will freeze on Arnova logo.. someone help me pls!
117 Guest(s)
Devices in use: Desktop (104), Phone (13)
smalec
marek.test@gmail.com
MINIX2021
extendedtn
salimdz16
anonymunbekannter14
