Arnova ChildPad&7d G3 Android 4.0.4 + CWM Recovery custom firmware
vlynn8800
46
2012/11/01 - 19:37
Do you have one for the resistive models? Won't work on mine, would like an update for this.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
47
2012/11/02 - 17:34
We would like to know how this SetupWizard from Arnova works, so we can add the screen calibration for the resistive... For now, nothing.
zaxarop
48
2012/11/18 - 11:35
I install "Arnova ChildPad&7d G3 Android 4.0.4 + CWM Recovery custom firmware" (AN7DG3-CP20120919EV2.3)
I have two prooblems:
1.
 When i try to install apps from google play or for Applbs i take this message: "It's no possiple to install on the SD card"
    I read at forum (post 12) and format the SD card. After that everything is OK.
    I close the pad but today when i open it i have the same problems without to be able to play even the installed apps.
2. Some apps i can't play. For example: Angry birds, Angry birds RIO install and play. Angry birds seasons install but no play.
How can i fix this problems?
If i install the JB version i have problems?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
49
2012/11/18 - 12:43
JB doesn't have that issues.
vandrommethomas
50
2012/11/21 - 18:59
exelletor said
You are in the wrong recovery. Open device manager on your pc, and just insert a paperclip for a few seconds until you hear a bleep sound(on your windows machine) and unknown device appears.
I have the same problem. can't get in the right recoverymode then. how do i exactly do that?
Ok, found that one out.
But i still get an unworking touchscreen with a capacitive version.
Help!
b.breum
Forum Posts: 91
Thanks Received: 12
angler
52
2012/11/24 - 02:10
mikemover said
No panic ... No panic ... it's working again.. right on time .. daddy where's my tab???? right here!! Play store works fine :)
even with the 4.0.4 thumbs up for you guys!
I have same problem - stucked at Choose language Google Android start screen - but I cannot choose country or press next (or ok for shutdown for that matte)
what did you do?
85 Guest(s)
Devices in use: Desktop (81), Phone (4)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
