Arnova ChildPad&7d G3 Android 4.0.4 + CWM Recovery custom firmware
mikemover
31
2012/10/04 - 14:58
I've managed to get this update on my childpad .. But now i have a problem with google play store.
When ik wan't to install apps i get the message;"device is not compatible"... never had this problem before.. :(
Is there a fix for this?
thnx
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
32
2012/10/04 - 15:17
Did you apply the "screen density fix"? Which apps are not compatible?
mikemover
33
2012/10/04 - 15:50
Yes I did the density fix. Facebook, cymera etc. etc. these apps did perfectly work before i updated :) also with the density fix.
I'm putting it back to stock rom and give it another try! :)
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
34
2012/10/04 - 15:59
In the blog post it says you shouldn't do the density fix before launching Google Play.
Just a fix for that(I don't know whether you are back to our kasty fw or not):
- put it back to normal (120)
- clear Google Play's cache and data
- reboot
- launch Google Play Store
- change the density back to your liking. ;)
mikemover
35
2012/10/04 - 18:28
my godness... I've put the original stock rom on my childpad ... No i'm facing the problem that my touchscreen doesn't react!
It say's in the left upper corner "Please touch this point" but the screen doesn't react ... :(
mikemover
36
2012/10/04 - 18:54
No panic ... No panic ... it's working again.. right on time .. daddy where's my tab???? right here!! Play store works fine :)
even with the 4.0.4 thumbs up for you guys!
j_friedel
37
2012/10/06 - 12:26
Hi
I've upgraded my childpad with your first CFW without any problems.
Now I was trying to go to the 4.0.4 but it doesn't work. When connecting the tablet in recovery mode it uses a different device ID. I added the following two lines to rockusb.inf:
%RK29_DeviceDesc%=Rockusb_DDI, USB\VID_18D1&PID_D001
%RK29_DeviceDesc%=Rockusb_DDI, USB\VID_18D1&PID_D001&REV_0222
The driver got installed and I started EvolutionRKtool. I got some error messages when clicking EraseIDB, so I changed setting.ini accordingly to:
[DEVICE_ID]
VID=0x18D1
PID=0xD001
But still I get an error message ("error during boot download" or the like).
Do I also have to change the values of [MSC_ID] and where can I find the correct values?
Any other ideas?
Marinka
38
2012/10/07 - 17:00
Had installed new firmware, but lots of problems appeared so far.. - could not install some applications which were installed before, still could not move applications to SD card, though the button "move to SD card" exists, it says "could not move application". Could you kindly help me to settle these problems? Many thanks in advance!
b.breum
Forum Posts: 91
Thanks Received: 12
Marinka
40
2012/10/08 - 21:46
Thank you! It's ok now :-) Kiss
t23
Forum Posts: 27
41
2012/10/08 - 23:14
Here's a rundown of the six USB connection modes, what works and what doesn't:
- MTP: No changes, if it worked with the stock ROM or kasty 40-04, it will still work.
- PTP: Same as above.
- MTP + USB debugging: ADB still works, MTP not possible while USB debugging is enabled, didn't work in stock or kasty 40-04 either.
- PTP + USB debugging: USB Device 0E79:145B appears (not apparent in kasty), ADB not working - solution in next post.
- Mass storage: Shows up on my machine as "Linux File-CD Gadget USB Device", but installs just fine as USB Mass Storage device.
- Mass storage + USB debugging: Mass storage works fine (disconnects and reconnects when toggling USB debugging), USB Device 0E79:1457 appears (not apparent in kasty since mass storage didn't exist in it), ADB not working - working on solution.
Conclusion: MTP and PTP never worked at the same time as USB debugging anyway, but let's fix the unknown devices, because we really want Mass storage mode to work at the same time as ADB.
WARNING: If you do not know the anatomy of an .inf file (or don't even know what an .inf file is), i suggest you do not follow this recipe!
First i assume you have the ADB driver installed already. If not, head over to the following URL and follow that recipe (Arnova have the same Vendor ID as Archos): http://www.archos.com/support/support_tech/updates_adb.html?lang=en
Then we need to find the right .inf file in c:\windows\inf - it is typically called "oemXX.inf" where XX is a one to four digit number. Note that the location might differ for you - i'm still on XP. The file can be found doing a text search for "Android WinUsb driver installation" without the quotes.
Then we have to add a few lines, BOTH to the [Google.NTx86] and [Google.NTamd64] sections. They are as follow:
;;; Arnova ChildPad (capacitive, UMASS)
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_1457
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_1457&MI_01
;;; Arnova ChildPad (capacitive, MTP)
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_1459
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_1459&MI_01
;;; Arnova ChildPad (capacitive, PTP)
%SingleAdbInterface% = USB_Install, USB\VID_0E79&PID_145B
%CompositeAdbInterface% = USB_Install, USB\VID_0E79&PID_145B&MI_01
Save this file with the changes, pull your USB cable if connected, insert it again, enable USB debugging on your CP, and choose each of the three USB connection modes in succession, waiting for the drivers to install every time.
This works for me - YMMV - and both gives you the combined Mass storage + ADB mode, plus it gets rid of those terrible unknown devices in device manager. Note that if your Windows doesn't pop up offering to install the driver in any of the three modes, you will have to find the device in Device Manager, right click and choose "update driver".
Hope this is of use to someone!
nikgl
42
2012/10/10 - 08:52
Hi and thanks a lot for the new firmware. It is really great to have this better experience.
What seems to be serious is that after applying the trick for installing the apps that couldn't be installed (trick with unmount/mount) and then moving them to internal sdcard a new problem appears.
Specifically, everytime that i restart the childpad, apps are not accesible. I need to unmount/mount again the internal sdcard so as to make them accesible again.
I moved the apps with Titanium backup and not with the default ics way. But i think that this has nothing to do with the problem.
Now, everytime that my son turns on the tablet, he asks me to do that procedure again.
For those that can't move apps to internal sdcard just unmount and mount it again. Then works ok. But how we can fix this?
Thanks again and waiting for the JellyBean firmware!!!
P.S. How we can take advantage of the external sdcard?
Is there anyone that upgraded with this firmware and put 1.5 GB setting for the apps partition of internal storage? Rhis was my first try, but when i restarted form CWM touch i was stacked in the arnova logo. So i did the procedure again for 1G and worked ok.
t23
Forum Posts: 27
43
2012/10/10 - 17:45
After 48 hours of working just fine with 4.0.4, my CP also does the "App not installed" thing now, and it takes me several remounts to get it working again.
As for taking advantage of external (as in real) SD cards, the /mnt structure needs a few changes, since it is wrong. The physical SD card should be mounted inside the NAND mount folder, and not next to it. Three files in kernel.img and one in system.img need changes, and i do not have the required skills to do this.
There are more bugs in /init.rc - all those numbered folders in the root directory are due to bad mkdir syntax. If exelletor would like to fix all this, i'd gladly help where i can.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
44
2012/10/12 - 23:29
Sorry guys for this mistake... Currently, I don't have the time to fix it and the skills to fix the kernel. On the other hand, with JellyBean, this cfw will not be really needed anymore. Smile
t23
Forum Posts: 27
45
2012/10/12 - 23:40
Well, i have two Debian boxes running here, if someone have a tutorial how to make the kernel image (which looks like a gzip of a cpio archive with a header and a footer to me), i'll give it a try.
115 Guest(s)
Devices in use: Desktop (111), Phone (4)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
