2012/09/27
Hello.
I'm having a problem installing various large games... When installing using adb, I get the error "INSTALL_FAILED_CONTAINER_ERROR", and the logcat shows:
E/PackageHelper( 1008): Failed to create secure container smdl2tmp1
D/VoldCmdListener( 66): asec create smdl2tmp1 27 fat {} 10038
E/Vold ( 66): Error creating imagefile (Read-only file system)
E/Vold ( 66): ASEC image file creation failed (Read-only file system)
W/Vold ( 66): Returning OperationFailed - no handler for errno 30
E/DefContainer( 1008): Failed to create container smdl2tmp1
Reading here: http://androidandsandu.blogspot.de/2012/04/how-to-resolve-installfailedcontainerer.html
looks like it happens when packages have external storage set as preferred for installation, and the kernel is missing some options when it was compiled.
Anyone experienced similar problems? For example, newly released 'Bad piggies' has this problem.
2012/09/27
exelletor said
Actually, this firmware uses the stock kernel, I didn't recompile it... Did you have those issues on the stock firmware too? And what if you install them by just copying them to the internal memomry of the tablet?
I don't know if it's the same on stock, as I installed the ROM right after getting the pad out of the box
I can do 'adb push whatever.apk /data/app', but it won't show in launcher. If I try to install it from there, I get the same error in the log files.
2012/09/27
exelletor said
I think, at this moment, the only option would be just to copy the apks to your userdata (with adb adb push whatever.apk /sdcard/) and install it from there... I will see when I can learn how to compile a new kernel and possibly fix this for you.
I tried that, and still get the same error. Even when installing directly from Play. Could you try installing Bad piggies, for example?
I will try installing the JellyBean test rom, will let you know if the same problem appears there.
62 Guest(s)
Devices in use: Desktop (51), Phone (11)
