Arnova ChildPad capacitive test firmware from Android 4.0 ICS official firmware 09/26
medeni73
Forum Posts: 51
Thanks Received: 8
61
2013/01/07 - 20:28
I'm glad I could help someone : I can confirm too that latest firmwares give just 500 Mb space... I always get just internal storage and external sd card but nand flash doesnt get mounted somehow...it just says mount sd card but when i press it it doesnt do anything nand flash is gone...
slupz
Forum Posts: 20
62
2013/01/09 - 20:50
hi,
I put the 50g version of the firmware and I have to say that it works really well, I just can not move applications to sd card because it sees it as external_usb, it is a shame not to use 16 gb of space
thanks
slupz
Forum Posts: 20
63
2013/02/08 - 16:45
hi,
il mio childpad ha 4G però con questo firmware ne vedo solo 2G Cry
Thanks Received: 268
64
2013/02/08 - 19:26
e cosi perche 2gb sono usati per le applicazioni,quindi con la stock firmware lo spazio era da sola 512Mb, prova escrivere in inglese perque not tutti capisco italiano
slupz
Forum Posts: 20
65
2013/02/09 - 10:17
sorry but I do not know how I was when I wrote translated into Italian.
I wanted to edit fstab to read the micro sd card to use for applications, how can I do?
the current fstab
dev_mount sdcard / mnt / external_sd auto / devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount udisk / mnt / usb_storage auto / devices/platform/usb20_otg/usb1
but seeing parameter, as I understand them decide how to partition the disk. But I do not understand how to give the size.
slupz
Forum Posts: 20
67
2013/02/13 - 23:11
globula_neagra said
http://www.arctablet.com/blog/forum/archos-arnova-childpad/rootapp2sdextgoogleplay/
very well,
you can install the google apps?
thanks
slupz
Forum Posts: 20
68
2013/02/24 - 13:15
someone managed to install gtalk??
dadaz20
69
2013/03/08 - 17:57
This is awesome..no problem with installation...very thanks to the admin..my sister's childpad now is no longer boring:) i think this is the best firmware so far...Laugh
The following users say thank you to dadaz20 for this useful post:
b.breum
b.breum
Forum Posts: 91
Thanks Received: 12
70
2013/03/08 - 20:21
Its not that the post is that usefull as such but its nice that you take your time to write back your feedback and that you enjoy the work the admins put into it.
carrote
71
2013/03/10 - 19:44
hello i have a problem with the childpad capacitive  after simplified flash my screen doesn't work and i don'tknow how switch on in flash mode for using rockchip
please help me
thannk you
sebastien123
72
2013/06/23 - 21:41
Exactely the same. After a lot of tries to install GooglePlay with ArcTools which always fail with error 20 and 28, i tried the firmware proposed by arctools. Then the screen stops working. Very very very disapointing !
I tried to download the original firmware. The link is bad ....
What can i do ?
scym
73
2013/08/02 - 01:19
meme chose...que faire???
74
2013/08/03 - 14:45
What can i do ?
You can look for another firmware, there are around 5 versions of ChildPad.
thesniffer
Forum Posts: 13
75
2013/11/05 - 23:25
Hi all, i have a childpad model AN7DG3C with firmware17/05/2013 build 1.11.
I couldn't find this firmware on Arnova download site and i discovered that my tablet is actually a Tabeo model.
My question: is there a way to dump my actual ROM coz i'd like to try to flash the tablet with another firmware in order to unlock the google play store and to get it rooted, just to have the chance to restore it in case something goes wrong (unresponsive touchscreen).
Thanks in advance for your answer  Wink
Currently Online: Stellar7
98 Guest(s)
Devices in use: Desktop (63), Phone (36)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
