Arnova ChildPad capacitive test firmware from Android 4.0 ICS official firmware 09/26
megapaul
46
2012/12/20 - 23:20
I downloaded the new firmware from the first post.
Everything is working fine but the internal memory for the apps is 512 MB.
I installed an app called app 2 sd to move some apps.
but i can't move the apps to the 2 GB internal space that i have also when i insert a memorycard i can't move the apps.
any solutions for this?
mainio77
47
2012/12/22 - 09:58
I have also this problem.
I have tried to put this new one to my device, but I have problem connecting to rockschip batchtool.
No device connected
  driver is correctly installed and tabled is in right mode?
What else there is to do?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
48
2012/12/22 - 13:33
Open your windows device manager and see whether a RK29 device is connected. If not, did you put your ChildPad in flash mode(pressing reset pinhole in until you here a device connected sound from windows)? Is the tablet screen turned off?
kotzo
49
2012/12/25 - 22:46
Same Problem with me. Only 512 MB
Thanks Received: 3177
50
2012/12/25 - 22:50
We'll soon publish a custom firmware update for this particular firmware with 2 GB space for applications (/data).
impreza
51
2012/12/26 - 07:20
needing to flash standard firmware back to this device, anybody have any links for this?
my model is uk big buck bunny version,
thanks.
52
2012/12/26 - 10:36
Here is a firmware update that should enlarge the space for applications (/data partition) up to 2 GB.
It should be installed only using Rockchip Flasher and used on newest ChildPads (Big buck bunny models)
Download: kasty-arnchilpadc-40-050g-2G.zip
Please note that I don't have a ChildPad so I can't test, so your feedback is welcome.
morpheus883
mezcal
53
2012/12/31 - 14:24
hello every one :)
For resum the situation someone could tell me or indicate me a positive feedback for the new FW linked in this topic to have 2Gb ?
 is it working fine for the CP childpad alvin and chimpmunks with from 26/09 ?
best regard and happy new year in advance :)
TEDUS
54
2012/12/31 - 18:03
hello
sorry for my english
thank you for your new firmware kasty-arnchilpadc-40-050g-2G.zip, I install for my chidpad and it s working well (google play store, space with 2G,....etc ) we have no problem and my daughter is very happy...
thanks so much and happy new year in advance Laugh
kunal_anand
55
2013/01/02 - 12:51
Hi
I have updated the Rock chip drivers on the PC. How do I go ahead from there? I can't transfer the firmware using the flashing tool. The tool shows up in Chinese.
I have spent hours on this. Please help.
Thanks Received: 268
56
2013/01/02 - 19:31
You can select the language, it is the first box from left to right, just click on it and select english
Use the restore option, not upgrade.
mezcal
57
2013/01/05 - 14:19
Hello everybody ! i come to give you my feedback on the last firmware linked to have 2Go storage !
my childpad is an CP alvin chimpmunks model !
whatever the firmware i installed ( the one from 26/12/2012 for 2Go or the first one posted for 1Go storage) i always have 512 Mo of intern storage and i never success to have 2Go !
Please help, how to have the famous 2Go of storage ?
best regards.
ps : this is the only Fw that works on my device, the other FW from other topic had pb with touchscreen that wasn't working on it.
ps2 : the FW for the  Big buck bunny models works great on the alvin models :) ( but for me with just 512 Mo instead of 2Go)
mndgz
58
2013/01/06 - 13:27
Hi all,
Flashed the capacitive Childpad with AN7DG3-CP20120919EV2.3 using the Flashtool and sure enough the touchscreen stopped working. I downloaded the 09/26 firmware and copied the update.img from SD card to /mnt/sdcard but the firmware upgrade screen would not come on. Tried the official update.img from Arnova website but that does not work either.
When connected to a Windows 7 PC the Childpad comes up as AN7DG3-CP and none of the drivers work (tried Rockchip 1.5, 1.9).
I can operate the Childpad using a USB mouse.
If someone could suggest an alternative way of installing the 09/26 firmware it would be greatly appreciated.
stevedee
Forum Posts: 19
59
2013/01/07 - 17:37
best regards.
I have the same problem ...
mezcal
60
2013/01/07 - 18:44
@Stevedee :
hello, i give you my feedback about a good solution for me :
follow the post number 28 from this link : http://www.arctablet.com/blog/forum/archos-arnova-childpad/wlan-problem-with-childpad-after-flashing/page-2/
if you follow step by step this " tuto" you will have a CP Childpad with wifi touchscreen and all ok, and under 4.1.1 JB ! A wonderfull solution !
many thx to medeni73 who posted this link in first :)
Best regards !
ps : my son is very happy
The following users say thank you to mezcal for this useful post:
stevedee
72 Guest(s)
Devices in use: Desktop (69), Phone (3)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
