stevedee said
Hello exelletorcan you change the kasty custom firmware with the newest Official FW version http://arnovatech.com/support/firmware/3/arnovachildpadalvincapacitive/120926/update.img ???? Maybe then the display is working properly.
I have built a custom firmware based on this latest Arnova update (09/26), please test and let us know if it goes better with the display problem. If this one works fine, we may be able with exelletor to fix the problem on the other firmware.
kasty-arnchilpadc-40-050d-2G.zip  (firmware for ChildPad capacitive model only)
Please note that I don't have a ChildPad, so I can test myself this firmware I have build.
Edit 2012/12/14: updated post with latest file:Â kasty-arnchilpadc-40-050d-2G.zip
Removed older test firmwares
stevedee, medeni73 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I'll double check my build and provide a fixed one.
I'll move the discussion to my test firmware in a separate topic.
stevedee, jasc If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Problem fixed, here is a new test file:
stevedee, jasc, virus2013, spaanmarino, angler, kostakimu If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/22
i will try in a few min to flash it to the resistive version with a kernel from the resistive. i will post updat. thanks for your hard work for all childtab users in the world.Â
edit: it soft-bricks the device the device dont do anything anymore
had to reflash the only resistive flash again
You can try, but there is little chance for it to work as the system is a little different for the resistive version.
Probably best to use the original custom firmware:Â
http://www.arctablet.com/blog/featured/arnova-childpad-custom-firmware-google-play-root/
sorio If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/01
Hello, thx a lot for your job ! it's working fine for mine
Just a question : is it possible to have a biggest partition because i saw that i have juste 567 Mo for the internal storage, and i remember that on anothere CFW for the Childpad, it was possible to choose : 560Mo, 1Go or 1.5 Go for the internal storage format !
Thx to keep me in touch for this !
Best regards and thx again for your great job
My son will be verry happy for X-mas
2012/11/30
Am I understanding this correctly: this is the same firmware like "Arnova ChildPad&7d G3 Capacitive Android 4.1.1 JB Custom Firmware" just with newer original firmware files (instead of 20120608 now comes 20120926)??? And what corrects this version? I will get ChildPad (capacitive one) in a few days and will flash it with your firmware but now I'm not sure if its safe? What screen problems are there? Could someone flash it successfully or not?
81 Guest(s)
Devices in use: Desktop (74), Phone (7)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
