Arnova ChildPad capacitive and resistive models ICS custom firmware with Google Play and root
jasc
106
2012/11/15 - 23:44
Great Thanks
I sure my son will be very greatfull if you can fix thisSmile
stevedee
Forum Posts: 19
107
2012/11/17 - 19:00
Hello exelletor
can you change the kasty custom firmware with the newest Official FW version http://arnovatech.com/support/firmware/3/arnovachildpadalvincapacitive/120926/update.img ????  Maybe then the display is working properly.
sam123
108
2012/11/17 - 20:52
Hi, I'm very new hear and i'm hoping for quick replies as i've made a mess and need it fixed for christmas. okay, so I bought an arnova childpad for my daughter (ref: 502170) and tried to flash over the firmware for google play (kasty-arnchilpadc-40-04) however, now the touch screen doesn't work. any suggestions on how to get it working again?? also, can someone tell me how to put it into flashing mode, as i am having trouble with that as well, thankyou.
EDIT: Also, when plugged in and I press the rest button, my windows makes the initial connecting sound, then like a dun dun dun..any ideas?
b.breum
Forum Posts: 91
Thanks Received: 12
109
2012/11/17 - 21:02
sam:
u need to reflash this
as of now some newer versions of CP doesnt have a working touch screen after fllash.
It will change we hope.
so for now it doesnt seem to work.
If you can flash so just google play works? Dont know, but if it was me i'd wait for them to do their magic and fix it :)
ANd then BE VERY GRATEFULL FOR THEIR HARD WORK
psst... that sound is ok!
sam123
110
2012/11/17 - 21:04
thank you so much:D:D:D now, for the stupider question, how do i put it into flash mode so that i can use the rockchip program? thankyou!
EDIT: I am seriously stuck on the flashing mode, followed by the rockchip flashing tool, i cannot find the drivers anywhere..sorry for any inconvenience caused!
falvarado
111
2012/11/17 - 21:24
Hi All, can you tell me if the rockchip flashing tool is available for MAC OS?
many thanks
b.breum
Forum Posts: 91
Thanks Received: 12
112
2012/11/17 - 21:28
For me the drivers are here
C:\...Downloads\Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5\RockusbDriver
then u choose if u have x86 or  x64 bit
The following users say thank you to b.breum for this useful post:
sam123
b.breum
Forum Posts: 91
Thanks Received: 12
113
2012/11/17 - 21:30
many thanks
I couldnt find it anywhere but wouldnt a guy who owns mac os use ipad? CoolLaugh
falvarado
114
2012/11/17 - 21:39
b.breum said
many thanks
God's ways are inscrutable...... I own a Galaxy Note as smartphone a Nexus 7 as tablet, a childpad so my daughter stop asking to use my Note to do games and an iMac to write this post  Wink
sam123
115
2012/11/17 - 21:45
you, are beautiful. thank you!
sam123
116
2012/11/17 - 22:12
hi, so i restored it like you suggested, yet it now has no third party apps like applib? any suggestions? thankyou
EDIT: I have figured out how to run programs without downloading them, but my main question is now: is there an app store program? thanks
b.breum
Forum Posts: 91
Thanks Received: 12
117
2012/11/18 - 09:02
yes applib u just go to that place via your browser and then u install it from there.
If you dont succeed i can mail you the apk file from applip
But here is the link u need to go to in your Childpads browser
appslib.com/latest
info taken from this site
http://appslib.com/download/index.html
edit: direct link to the apk file so you can download it
http://files.appslib.com/apps/marketplace/v2/Appslib_2.apk
sam123
jasc
118
2012/11/18 - 11:27
Had the same problem after flashing my own ChildPAd.
The app's and other files orginally on the Childpad can be downloaded from the link below
ftp://support.arnovatech.com/
If you flash the Pad and copy the "system" folder to the root of the unit, all the app's will be installed during configuration.
The following users say thank you to jasc for this useful post:
sam123, stevedee
sam123
119
2012/11/18 - 12:04
You guys are truly a great help, and so i depart with one last question: The childpad logo on start up - is there any way to change that?
Thanks Received: 3171
120
2012/11/18 - 21:13
I don't think there is an easy way to change the startup logo.
Actually there are 3 stages of logo display, the first two are located in the kernel and boot images, which require some technical knowledge to edit. The third part and longest to display logo (usually it's a small animation made of a few pictures) goes to /system/media/bootanimation.zip file.
You should be able to find some tools to make one on the Internet and a root file explorer to copy the new file on your tablet.
73 Guest(s)
Devices in use: Desktop (69), Phone (3), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
