Arnova ChildPad capacitive and resistive models ICS custom firmware with Google Play and root
bdejonck
Forum Posts: 32
76
2012/08/10 - 10:31
b.breum said
kasty-arnchilpadc-40-04 with that file
Filename looks incorrect Laugh
Did you take the link from post 19 : http://www.arctablet.com/assets/firmware/ArnovaChildPad/kasty-arnchilpadc-40-04-1G.zip ?
That's the 1Gb version.
b.breum
Forum Posts: 91
Thanks Received: 12
77
2012/08/10 - 10:43
Where did u find that link? on that page?
I can only find the link to this
http://www.arctablet.com/assets/firmware/ArnovaChildPad/kasty-arnchilpadc-40-04.zip which i downloaded
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
78
2012/08/10 - 10:47
Post 19(from admin):
My apologies, the custom firmware with 1 Gb space (instead of 512 Mb) for applications was published but only privately.
Here it is:
for the resistive ChildPad: kasty-arnchilpadr-40-041-1G.zip
for the capacitive ChildPad: kasty-arnchilpadc-40-04-1G.zip
Choose the right firmware for your tablet and flash it with Rockchip flasher.
b.breum
Forum Posts: 91
Thanks Received: 12
79
2012/08/10 - 10:48
Im sorry didnt fully read your post
u said post 19, so found post 19
and the answer, it was posted privately.
Its now flashing again :)
so nice to get a new toy aint it ;)
bdejonck
Forum Posts: 32
80
2012/08/10 - 11:20
We always remain a child in some ways :-)
But as it is very new to my kids and they don't get bored playing with it, I hardly get some time to play with it myself. Wink
b.breum
Forum Posts: 91
Thanks Received: 12
81
2012/08/10 - 11:29
I also doubt how much im going to be able to play with it, but atleast untill its ready for him, its mine, hmm my wife's..
It now have 300MB of programs games in it and still 700 mb free space.
It runs so much more smooth than with arnova preinstall on it.
This is just great
Again thanks,
b.breum
Forum Posts: 91
Thanks Received: 12
82
2012/08/10 - 19:04
Update.
Its now fully installed with all things i think they should have access to an wordfeud for my wife :)
After 1 hour of playing lego
https://play.google.com/store/apps/details?id=dk.spatifo.dublo&feature=search_result
https://play.google.com/store/apps/details?id=com.lego.bricksmore&feature=search_result
I'll just say that its an amazing little tablet.
Thank you again for all your wisdom and help.
The following users say thank you to b.breum for this useful post:
PatriceB
tech44
83
2012/08/10 - 21:55
I apologize for my ignorance, however, when I open the Child Pad (resistive) tablet in my file browser, it shows storage space of 2.05 GB, does this make any difference when installing the update image to get Google Play installed?
Thank you
t23
Forum Posts: 27
84
2012/08/11 - 00:47
The capacitive image has 1.96GB storage, so i'd say it's normal. Add to that 1GB for your apps partition, and whatever the backup image takes, plus all the things i don't know what Android uses space for, and you get the 4GB that's physically in it.
bdejonck
Forum Posts: 32
85
2012/08/11 - 01:31
Thank you
If you count the values below, you will find 4 Gb :-)
root@android:/ # df
Filesystem             Size   Used   Free   Blksize
/dev                  399.8M  36.0K  399.7M   4096
/mnt/asec             399.8M  0.0 K  399.8M   4096
/mnt/obb              399.8M  0.0 K  399.8M   4096
/system               331.0M  288.6M  42.3M   1024 ( <- OS )
/data                 1007.9M  548.9M  459.0M   4096 ( <- system apps / dalvik cache / .... )
/cache                112.4M  4.2 M  108.2M   4096
/mnt/sdcard           1.6 G  342.8M  1.2 G   8192 ( <- usable space for the end user )
fashfd
86
2012/08/12 - 17:49
Installed the custom rom, but the only difference i've noticed is the boot loader and the google play store (and super su). Is there something I'm doing wrong as I installed one more app than what was on it before and then it said that i need to free up some more space. I thought the rom was supposed to give double the amount of user space for apps or did i misunderstand ?
b.breum
Forum Posts: 91
Thanks Received: 12
87
2012/08/12 - 18:11
So maybe you made the same mistake as I and downloaded the wrong firware since its hidden in post 19.
Find the right one for you and im sure it will work for you also
fashfd
88
2012/08/12 - 18:15
I downloaded the kasty-arnchilpadr-40-041-1G one as my childpad appears to be the resistive one.... (got it from post 19)
I wasnt sure if it was capacitive or resistive so tried using a pen lid to check for response on screen..It detected the movement so I deduced that it must be a resistive model ?? (although on the box was ref 502141 which makes it capacitive?)
Been playing around with it and still no joy im afraid....
If I download the capacitive one and try that will it brick the childpad ?
fashfd
89
2012/08/12 - 19:06
Ok, for anyone else who suffers the same problem as I did, don't upgrade with the image file.. Make sure you use the rockchip batch tool and all will work :)  Good luck, and make sure you back up your childpad first :)
b.breum
Forum Posts: 91
Thanks Received: 12
90
2012/08/12 - 19:33
Good to hear that you got it working
And no dont try to flash with image from capacitive if yours is resistive
easy to check if its one or the other. If you can get a reaction on the screen from the top of a pen then its not capacitive ;)
Or you can just check the serial number on the back, if i remember correctly then 512.17x is capacitive.
Enjoy it
77 Guest(s)
Devices in use: Desktop (70), Phone (6), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
